1956 F100 Crew Cab Project Started - LOTS OF PICTURES
Old 12-27-2014, 07:41 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,132 Likes on 2,656 Posts
Originally Posted by dynamic
next I moved on to the finial dash extension.
I took my mock up and transferred the measurements.
and we have a finished dash extension.
I built a dash extension like the one you have pictured here on my panel but my glove box was filled in, I'm doing a pickup now and made another extension the same as my panel but planned on keeping the glove box this time. I forgot how the glove box door opened, it doesn't work with this type of extension. I was thinking of using a piano hinge. Have you come up with an idea to mend this BOO BOO
  #287
Old 12-27-2014, 08:16 PM
dynamic's Avatar
dynamic
dynamic is offline
Well.... actually I have come up with a way to overcome the blocked glove box issue, and tested it to make sure it works.
I too have seen many dash extensions with the funny slot under the glove box in order to retain the function of the glove box.
However until I have a finished product I cannot divulge that information.
  #288
Old 12-27-2014, 08:24 PM
56panelford
I'm waiting for you to share your idea
  #289
Old 12-27-2014, 08:28 PM
dynamic's Avatar
dynamic
dynamic is offline
Until I get my oversized A/C - Heater installed and do my finial layout I cannot divulge that.
But don't worry, I will be sharing. And when you see what I have found to solve the problem you will be thinking "why didn't I think of that"!!!
  #290
Old 12-27-2014, 08:31 PM
56panelford
Does it require any welding? If not I can wait.
  #291
Old 12-27-2014, 08:46 PM
dynamic's Avatar
dynamic
dynamic is offline
Your application wouldn't require any welding. And my idea will be a screw in type install.
Because the area behind my glove box door is going to be very congested, I may need a weld or two for auxiliary brackets to support my install. I was able to mock up and test (successfully) without the a/c-heater installed. I need to double check the install once the finial brackets are made.
  #292
Old 12-27-2014, 08:51 PM
56panelford
I haven't picked up my A/C unit for this build yet but still have the shallow box left over from the panel that wasn't used. I'm interested to see what you have come up with so please keep me posted.
  #293
Old 12-27-2014, 10:21 PM
smallello's Avatar
smallello
smallello is offline
How soon will we know. I am about to build a dash extension and could use some ideas for the glove box door.
  #294
Old 04-26-2015, 05:17 PM
dynamic's Avatar
dynamic
dynamic is offline
Well gang, its been a while but after a long winter nap we are back at it again.
It was time to pull the engine / transmission and start boxing the frame.
Before starting to mock up the plates the chassis was treated to a pressure washing.
Then a template was made up out of white plastic and then transferred to some 1/8 plate to use as my boxing material.
Cut out rough.
And started fitting the plates to the chassis
fitted, clamped, ground, cut, fitted, clamped, ground, and repeated until each side was a nice fit.
  #295
Old 04-29-2015, 08:13 AM
56panelford
Looking nice and clean in there Tom, good job.
  #296
Old 05-12-2015, 11:13 AM
00Boss's Avatar
00Boss
00Boss is offline
This is a sweet build. I'm subbing for this
  #297
Old 05-17-2015, 05:25 PM
dynamic's Avatar
dynamic
dynamic is offline
Well, time to weld the boxing plates in....
Got the tops all welded in, laid on the creeper..... slide under the chassis.... flip down the welding lens..... click the trigger.... and no wire.
Thinking to my self that the wire must have fused to the tip....I slide out from under the truck.... check the tip.. and nope... no fused wire.
Further investigation revealed that the contactor on the old girl burnt out. Looks like the welding is over for the weekend.
so..... Sunday turned into a help my buddy build some doors for his wife's barn day.
  #298
Old 05-17-2015, 11:52 PM
smallello's Avatar
smallello
When will we see your idea?
  #299
Old 09-05-2015, 07:49 PM
dynamic's Avatar
dynamic
dynamic is offline
so we have been mudding, sanding, priming, filling our brains out...
starting to come together.
  #300
Old 09-05-2015, 07:51 PM
dynamic's Avatar
dynamic
dynamic is offline
yeah.... I know.... I let a cat out of the bag.... now every one wants to play.
Hopefully in the coming months I will get back on track.... stay tuned.
Quick Reply: 1956 F100 Crew Cab Project Started - LOTS OF PICTURES
