no dash lights , no tail lights
2000 f 350 when i turn on the lights i have no dash lights and no taillights, mini fuse #4 trailer lights; 20 amp is blown repalced several times, blows a fuse every time i turn the light switch on. havent been able to visually locate a bad wire . could it be the light switch, wich i have seen alot about on this site, or would it more likely be a shorted out wire some where? Thanks for any help
The trailer tow fuse being blown should not cause the dash or taillights to be out. I would check other fuses in the Power Distribution Box, and look for corrosion or signs of water intrusion in and around the relays. The trailer tow fuse being blown would seem to indicate multiple shorts.
It's possible, but I don't think it's likely.
It's certainly not causing the fuse to blow, because the trailer tow wiring doesn't go through there. And, the fuse blowing indicates that power is getting to the trailer tow running lights relay, which would seem to indicate that the switch is working.
fireeater91
29
12-31-2019 03:05 PM
stownsen914
01-22-2019 11:28 PM
SidWell
Electrical Systems/Wiring
08-20-2015 01:48 PM
