power steering pump help.updated and Concluded
So last Friday I decided to install a new PS pump. My old pump was starteng to whine a little and it had been run dry twice over the last 200K due to blown HP lines so I figured it would be good PM to throw in a new one.
I first purchase a reman Dorman pump from Oreillys, it lasted all of five miles but was incredibly quite and the steering was as smooth and easy as I have ever felt it....then it quit pumping. When I spun it by hand off the motor it had no fluid output.....they took it back no question's asked (makes you wonder)
I figured I would avoid the parts store for the second pump so I purchased a remaned Motorcraft from the dealership on saturday. They didn't have/cant get new pumps but I figured reman Motorcraft is still OEM so alright.
Installed the Motorcraft pump saturday after noon, filled it with fresh mobil one syn ATF and proceeded to perform a complete fluid flush and fill. I bled the system with the front wheels off the ground, turning the wheel adn applying the brakes. I flushed the system until the fluid was nice and red.
At this point it was still making noise (enough to be embarrassing) but I figured it would burp the rest of the air in a day or two and the fluid didn't look aerated so I wasn't worried.
Fast forward to Tuesday and I have put over 600 miles on this pump and it is still way to loud, steering is alright and brakes are fine but it is to dang noisy.
So Tuesday night I bust out the mityvac and a rubber stopper and pull a good vacuum on the pump reservoir and proceed to try and bleed any additional air out of the system. Damn thing is still noisy!!! But I figured I have to drive about 500 miles round trip to Medford Wednesday so it should be better by at least the halfway point...
Well here I am 250 miles down the road and the dang thing is way to noisy. It functions fine but the level of whining from the pump is unacceptable, it is loud enough to be embarrassing in parking lots.
So my plan is to dump some lucas power steering additive in it before I head home this afternoon, if it is still noisy when I get home Ford will need to get me another pump.
Any other ideas on how to get rid of this whine? ( the one from the pump not me)
finally got around to warrantying the pump so this morning at 8:30AM I went OEM again baby.
Finally....pump number 3 is a winner. It is quite, strong and doesn't leak. I got tired of replacing the Teflon washer on the pump side of the HP hose every time I swapped pumps so I bought a new HP line as well today.
Sequence I went through replacing this pump
1: install new pump in bracket
2: install pully on pump
3: attach bottom and top LP hoses.
4: fill pump with fluid and spin it over slowly by hand until fluid starts to flow out the HP port.
5: attach HP line and spin pump over some more until it stiffens up and and fluid is no longer dropping in the reservoir
6: install belt any thing else you removed and call it a day.
I had the front tires off the ground to bleed the system but I had zero air in the system so it wasn't necessary. After I started the truck cycled the box and worked the brakes the level never dropped and the pump never made a sound.
Hope this helps someone out there in future.
Mine blew a HP hose about 6 months ago on the road. lucky i only had to walk about a mile to get a hose. I asked the guy as auto zone what fluid it took. I didn't know at the time..
He said just use normal PS fluid. After pulling the inner fender and cooler tube i replaced the line. I guess as i took off the old line, the inner Bigger line adapter has an o-ring on it. i guess it got a small tear in it during the replacement.
filled it up and bleed it out and had a small whine. as i drove it, it went away in about 40 miles. i stopped to get fuel and noticed the small leak. topped it off and back on the road. well the leak got worse and the pump started to whine. pulled over and refilled it in the dark.
got home and went to bed. got up and removed the line and adapter. installed new o-rings. Bled out the system with motorcraft ATF.
I ran three quarts through it. to this day and about 2000 miles i still have a slight whine when turning..
