October, 2011 Junk Yard Wishlist
#31
window switch
wishing for the driver's side electric window switch for an '86 f150.
tiny little bugger is shorting and preventing me from rolling down my driver's side window. Driver's side is a double switch which can roll down both driver and passenger windows.
thanks much if someone sees one.
#32
Do me a favor and finish filling out your profile so we can see where you're located, OK?
Click on User CP in the top-left to do it.
#35
I'm looking for a a dash pad. I Have about a third of one in my truck the rest of it looks like it was ripped out, its just not there you can look into the dash from the top of the dash.
#38
I'm looking for a rear driver's side door for my '85 F350 Crewcab. I've looked at all the junkyards in Iowa and South Dakota. The only one was in Iowa with rust all along the seams. Color doesn't matter as I'm eventually going to paint the truck. These rear doors are a real bugger to find. Thanks all.
#40
#41
Alright. So, my wishlist is kind of long, and full of items that are mostly readily available outside the junkyard. However, most private owners want more for these items than I'm able to spend, and I can't find anything that I want in my local Pull-A-Part yards (except for a 460 that had at least 4 slung rods. Might still go grab the mounts/perches/various and sundry 460 parts). This may be a long shot, but I figured maybe you guys could help me out.
1. Complete 460. Preferably '83-'86, but pre-'83 will work. Found one in an '86 F350 at a Pull-A-Part about an hour from my house. Worked my azz off to pull it, only to find that the motor had all kinds of holes in the oil pan. Looking to spend: $200-$250.
2. This one is an either/or. I want a 4x4 ZF 5-Speed transmission to fit a 460. I know this one will be exceedingly hard to find, so a 460 T-18 bellhousing, or an NP435 will suffice. Looking to spend: $100-$250
3. The extremely hard to find. I'm looking for a 77.5-79/85.5-91 High-Pinion, Kingpin Dana 60 front axle, not to be confused (which it often is) with the Dana 44 HD. The hubs on the D60 are shorter and fatter, and have bigger differential cover bolts than the D44 does. These can be found in select '77.5-'79 F-250's, the '79 F-350, and 85.5-91 F-350's. I know where these are for $1,000+, but Pull-A-Part only charges about $200. Looking to spend: $200-$400.
4. A Sterling 10.25 rear. I can get one of these for pretty cheap, about $100 at my local Pull-A-Parts, which seem to have a few of them, so this one isn't a biggie. But if you guys can find one for like $50, that'd be great.
Now, unfortunately, these are all big parts, so shipping is out. So if any of you guys to to yards that are within about an hour to two hour drive of Atlanta, keep an eye out. If you happen to spot one, let me know. It'll be greatly appreciated. Thanks in advance!
#42
Not sure how close these are, but they are some in Georgia, as found by Car-Part.com--Used Auto Parts Market
1987
ZF 5 speeds transmissions:
Transmission
Ford Truck F250 XL,7.5 ,4x4,CHECKSPEED T50019 $950 Jonesboro Auto Salvage USA-GA(Jonesboro) E-mail 1-770-477-6663
1993
Transmission
Ford Truck 450 Series 4X2,7.5,5SP,FLR,5-93 0 A B10784 $700 Hon's Automotive USA-GA(Cochran) Request_Quote 1-800-852-1526 Request_Insurance_Quote
1989
Transmission
Ford Truck 450 Series 2WD,7.5,5SPD,FLR 001676 $650 Four Lane Auto Parts USA-GA(Cartersville) E-mail 1-770-382-3399
1987
Transmission
1993
Transmission
1989
Transmission
#43
Looking for T170 trans. 3 speed + OD (RTS tag code). Needed for some gears to fix mine. Need 2nd gear and the gear cluster in the bottom of the tranny. The big one that has 4 gears on it. If you have one with a busted case or something, PLEASE send my way. Or if you've torn yours down and don't plan on rebuilding, message me and we can compare gears.
#44
Looking for an original tailgate for a base model 85 F150, preferably brown or some color that won't look horrendous with my brown truck. other colors can be painted though
#45
