Yes, it should. It is located on the rear of the passenger side valve cover. I have a pic in my "'92 Ol'e Blue" album if you need a pic of the location. If you are replacing it, be sure to spend the extra few dollars and get a Motocraft PCV valve as a replacement. Not an OEM equivalent. Your local Ford dealership has them for about $7 or 8 bucks. Hope this helps.
Thanks Wes. Great picture. Would you also have a picture of the a/c componets on the same engine. I have what appears to be an a/c pressure switch located right by the oil filler cap. The switch is there with two wires coming out of the top that someone has cut. I am looking to reconnect them.
Thanks again,
Harley
Thanks again,
Harley
Ummm I'm not sure of what you're meaning...There is no A/C components ON the engine, except for the A/C compressor....
My PCV valve is new all filters are new plenty of suck on the PVC valve and plenty of blow out of the other side (next to oil fill) however there is so much blow, it will blow a quart of oil in 75-100 highway miles out of the air filter intake therefore soaking the air and PCV filters, running down the inner fender. Help! Any suggestions?
