fuel gauge stuck on Full
Old 12-04-2013, 08:28 PM
pops_91710's Avatar
pops_91710
pops_91710 is offline
In my case which was just resolved in late September it was the fuel sending unit wires had looped themselves around the float arm and held the float in the Full position. The wires need to be tie-wrapped to the rheostat mounting plate. Easy fix.
Old 01-31-2014, 08:33 AM
wwelder's Avatar
wwelder
wwelder is offline
The same problem on 2007 with v10. The float mechanism jarred loose from the pump and floating around in the tank.
Old 09-15-2016, 07:26 PM
ford4x4s's Avatar
ford4x4s
ford4x4s is offline
fixed
after reading the posts i figured i must have a stuck float......with a half full tank i put it in 4 low and hit the gas and then the brake a few times and then a few times in reverse.....got the fuel sloshing around pretty good....guage went back to normal and has been fine all day.....FTE for the win once again!
Old 12-31-2017, 01:00 AM
sig1911's Avatar
sig1911
sig1911 is online now
well I hope my float is just stuck. I went to sturgeon bay Wisconsin for Christmas from the Houston area and tried to pull a moving truck out that had ran off the driveway into the yard that was about a foot and a half drop and I yanked on him a few times and never could get enough traction to get him out. I got close a few times and got him about half way or so up over the bump but once I was done I notice my fuel gauge showed me having a full tank and I knew I only had a half a tank or less.
Old 01-01-2018, 09:22 AM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
I had a similar problem but noticed that sometimes when I turned the key on the fuel gauge would read full and if I turned the key on and off quickly it would then read correctly. This didn't work all the time but made me wonder about the switch under the column that is actuated by the key.
I purchased a used one for $10 off eBay and installed it. My fuel gauge has been working fine ever since.
Here's a link to one: https://www.ebay.com/itm/FORD-IGNITI...NZONhv&vxp=mtr
Old 01-01-2018, 03:22 PM
sig1911's Avatar
sig1911
Thanks I will try that
Old 01-01-2018, 03:47 PM
jimjokjv's Avatar
jimjokjv
jimjokjv is offline
Be sure to check your dash grounds also.
I believe there is one under your driver's side kick panel as well as up under the dash.
CGMKCM's Avatar
CGMKCM
CGMKCM is offline
Originally Posted by twags6
Full throttle starts in 4x4 on 3/4 of a tank will get the float wedged at the top of the tank too! I've done it once and I thin Joe (Izzy) did it too.
That's how I made mine stick. New tunes, Adrenalin, hutch and harpoon mod done all at the same time. I just had to see what she would do. Tank was about 1/3 full. You pay to play.
Old 07-18-2018, 12:21 PM
dmueller71's Avatar
dmueller71
dmueller71 is offline
I just pulled the tank to fix the same probleml. I thought by disconnecting the plug for the sending unit would get me an E reading, but apparently that isn't the case, so I finally gave in and pulled the tank. In my case, the wire broke off of the sending unit. 2 min with a soldering iron and it was fixed
Old 07-18-2018, 08:19 PM
sig1911's Avatar
sig1911
I'm planning to do to that eventually for now I just go off my tripometer. I have looked under the dash and didn't notice anything loose.
Old 07-18-2018, 09:40 PM
dmueller71's Avatar
dmueller71
My broken wire was on the sending unit in the tank
Old 12-16-2019, 08:38 PM
Anthony Campos's Avatar
Anthony Campos
Anthony Campos is offline
Originally Posted by diesel-fitter-bum01
Fixed. The float was stuck up in the wires. Zip tied them together. So hopefully it won't happen again. Thanks everyone.
Hello, I caught the gas gauge going up to the full line and it's been stuck there for two days now. Could it be our problem is similar?
  #28
Old 12-12-2020, 08:46 PM
RacinJasonWV's Avatar
RacinJasonWV
RacinJasonWV is online now
Received 1,620 Likes on 1,142 Posts
Well I know I’m resurrecting an old thread but just wanted to thank the folks at FTE for coming through again. I’ve been working on my dad's neglected 2000 F350 today and one of the tasks was fixing the fuel gauge. It would go to above full with key on.
I found a broken wire near the connector at the frame and tank. There was enough wire to pull it out over the frame to work on it. A little solder and heat shrink and it’s good to go.
Thanks for all the info shared here on the forum!
Hutch17
13
12-27-2012 08:41 PM
Fordfanatic4life
1999 to 2016 Super Duty
18
02-18-2010 08:15 PM
stroken
18
09-29-2009 01:48 PM
884x4broncoII
12-31-2008 10:44 PM
69f250mg
08-13-2001 02:58 AM
Quick Reply: fuel gauge stuck on Full
