F250 5.4L pulling a 5th wheel - feasible?
#31
Thanks for the warm welcomes everyone!
I found the specifics on the 5th wheel - it's a Jayco Eagle 263. Sticker on the side says:
I'm trying to piece all these numbers together but so far it looks to me like the trailer exceeds what the truck should pull.
GVWR: / PNBV KG
9995 4548
I couldn't find specs on the 2001, but the 2002 F250 V8 5.4L Supercab 4x4 short bed looks like it has GCWR: 13,500 and Maximum Loaded Trailer Weight of 7,100 lbs according to: https://www.fleet.ford.com/showroom/...D_F250_350.pdf9995 4548
#32
With a 4:10 axel you would be right there at a GCVWR @15000lbs assuming you are loading the wheel light, remember the ratings Ford publishes are EXTREMELY conservative I scale my 07 for dune trips wet with fuel and toys and water for the week at 28500 to 30500lbs depending on wether I take the ranger XP on it's single axel trailer behind the wheel, and I have no pulling or stopping issues!
Jim & fat Monty
Jim & fat Monty
#33
#35
We tow a 30ft 8500~lb (10k lb GVWR) 5th wheel with our 2010 5.4L auto/3.73 F250. Around the southeast it does a fine job. 2700~rpm on the flats and 4200~rpm on the uphills. Maintains speed well. If that makes you cringe, you'll hate it. I'm very happy with it. I've owned six diesels so I'm familiar with them too. If you're not planning trips to the Rockies, it should do fine. I don't know what the hp/torque is with the older 5.4L. I think mine is 310/360.
#36
yep I too have had the 05 5.4 and pulled a bobcat with my f150, it did it ok for almost 9k in trailer and equipment. When you start reving in the 4k rpm range you are sucking fuel like no tomorrow. Working it hard and I know they dont mind it but if you want to do any nice towing I would just got with a larger engine and be done......Heck the old timers never had power like what we have today but they hauled and pulled monster loads with their old trucks.
#37
#39
#40
Im from Michigan myself and was a Chevy guy at one time. If your old Chevy 1/2 ton was a Z71 then it came with 3:73 gears, If it wasnt then it has 3:42 gears. I had a 97 Chevy Tahoe with 3:42 gears and it towed my 30 foot camper trailer decent. My trailer is around 6700 pounds. But when it was windy I felt a little uneasy. I now tow with my F-350 V-10 and it tows it great and I feel alot safer. Wind doesnt effect me at all and the trailer doesnt push me around like it did with the Tahoe. Sometimes I forget the trailer is even back there. I think a 5.4 would tow just fine. But a V-10 would tow nicer. Your old chevy was rated to tow 6500 lbs.
CrewCabLongbox
Fifth Wheel & Gooseneck RV Towing
03-01-2012 09:59 AM
FIRE CHIEF BUBBA
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-06-2011 12:04 PM
