Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- Why is My Power Window Not Working?
Guide to diagnose trouble and recommended solutions
POWER WINDOWS & RADIO electrical problem
#61
I have been experiencing my windows and radio not working more often since the outside temperature has increased. I live in Maine and only experienced the problem a few times from November to May. Now that the days are getting warmer the problem is occurring more frequently. It really stinks to get into a 90 degree vehicle and not be able to roll down the windows. Is there anybody who experiences an increased frequency with this problem when the temperature increases? If so, what would cause this problem to occur more often when it's warm?
#63
#64
#66
#67
Grounds are normally a good place to start looking. Is this ground on the inside (center) of the truck by the latch, or is it by the pillar where the actual seat belt and its ratchet mechanism is? I'd like to check mine if its not a huge ordeal.
#68
If it is just solder problems can the cluster be pulled and a heat gun used to "re-solder"? Much like can be done with the circuit board of a PS3.
#69
It's on the c pillar close to the 3rd row pocket. I happen to have my interior pulled right now, so i will snap a pic of it tonight.
#71
#72
#74
Replaced everything but the cluster-no luck
I have an '03 with a 7.3. I have had the same problem for two years. I am leaning toward a delay relay in the cluster. I would like to hear back fron the two guys that changed thier clusters.
My problem, specifically, the windows, radio, map/reading lights (on sides, not dome) and the glove box light all stop working. Mine come back on whenever; from 30 seconds to 10 minutes. After two years there is no pattern and this has happened 500 times. Warm/cold, accel/decel, headlights on/off; no pattern can be detected.
All my grounds, that I can find, are clean and tight. The only strange/different thing with my truck is the battery light comes on and off recently and a volt meter shows 13.1v at idle. So, I am getting a false error message when the light is on.
There are 10,000 posts, on numerous sites, on this problem and I cannot believe nobody has a conclusive fix. I am going to change my cluster with a junkyard one and see if that works. I can do that for free (have one on the shelf)and in less than 30 minutes. I will let you know. My problem happens more than once a day.
