Bypass the fuel relay switch
4.9 L. At the switch, cut the yellow wire. Cut the brown wire and hook it up to a keyed positive wire ( a wire that's hot when key is on ). Now if you've disabled some of the smog junk ( like me ), clip the red wire and cap it with a twist nut. The check engine lite won't come on anymore. I think that will disable the injector blower fan too, but i removed that stupid thing a long time ago. Irregardless, the red wire doesn't do anything important anyway.
NOT a smart thing to do!!
If I am reading right, he is talking about bypassing out the inertia safety switch. NOT a smart thing to do, as that is one of those things that is there for a reason. There is no sane reason to bypass that switch, and if you are in a wreck, the pumps can and will keep spraying fuel. You ever see what happens with an engine fire in a wreck, where 2 people are pinned in a 92-96 stepside and the relay doesnt kick off the fuel as it burns? By the time a rig got there, it was totally involved. Needless to say it was not a good night.
When that inertia switch fails, the motor won't start. Then you have to run down the problem and then buy the part. And what if the switch fails far away from home. What are most people going to do. Answer is that they will have the vehicle towed at $$. By taking that inertia switch out, a piece has been eliminated and fewer problem points. I bypassed the fuel relay switch cause i got a bad switch and there's no return on electrical parts. So now i don't have that part to fail, either.
Still a stupid thing to do!!!
Additionally, keep in mind, you are not only putting yourself at risk, but you are risking my life and my brothers lives (in addition to anyone you happen to get into a wreck with) as we are the ones who are running into the fray trying to put out the fire and save your @$$. And all because you want to save $25-30 on the cost of a replacement?
That's easy to understand. The hard truth is that lots of people bypass the inertia switch. It's a common topic to discuss. What i hear is people put a toggle in between the two wires as an anti-theft device. Hot wire the thing all you want. It still won't start until the hidden toggle is found.
Just because people do it doesn't make it smart or right to do. Same as drinking and driving, etc. Putting a hidden toggle switch to make it anti-theft doesn't require bypassing the inertia switch--- you can wire before or after it, or at the underhood relay for that matter. From a liability standpoint, get involved in a wreck that has problems caused by a inoperative switch that has been bypassed, and expect the lawyers WILL own anything you ever owned by the time they are done. In marine applications, have safety switches bypassed and the CG will ticket you on the spot (and tow the boat). It's like anything in life, there are right ways to do things and wrong ways to do things. As I said before, just to save the $25-30 for the cost of a replacement switch? Stupid, stupid, stupid. These items are NOT problem prone (millions of cars use them) and serve a vital purpose. Removing them does not increase power, reliabilty or mpg, which are the main reasons for removing/modding various factory components. Sorry, but you are not going to change my mind on the stupidity of doing a mod like this, and you stand and watch two people burn to death because of a fuel fed engine fire you would be the same way.
xxshine
08-09-2011 06:57 AM
Imaoleguy
1999 to 2016 Super Duty
09-23-2005 02:44 PM
