1992 ranger buket seats fitting in a 1991 f-150
All i know is that broncos and F?50s where all the same size floor pan wise. Thus the seats are "almost" interchangeable between them. All you have to do is grab all of the rails for the seat that you plan on using and make sure too reinforce the mounting holes that you "may" have to drill out in your floor pan.
Now as for a ranger seat fitting in a F?50, there should be more than enough room, matter of fact I will bet there will be a gap between the seat and the door and if you center the seat in the truck. you "might" find that you will be two or more inches too the right of your steering wheel. which can be really uncomfortable.
so as far as getting bucket seats in my 150 i need to stick to parts from a bronco hmmm.....i think there might be 1 or 2 at my local jy shouldn't be too hard....guys just a pain to deal with thank you for your help also a center console my 150 is a 5spd and i know it possible to still have the shifter and the center console it just fits around it (my uncle did the same thing with a jeep Comanche it had a bench seat with he swopped out the seats and and center console out of a jeep Cherokee and it was a 5spd im trying to get the same concept) is it possible?
I drive an auto, and I kind of like my bench seat. so, um, yeah.
Just make sure to grab parts from a full size bronco. I believe the center console out of a bronco will leave enough space in-front of it for 5 speed shifter but I'm not for sure. you will have to check for your self.
And just to make sure, reinforce any bolt holes that you Might have to make in your floor pan in your truck. Believe it or not in an accident your seat will rip out of the floor. Also check both sides before you drill. (I know both of those golden rules because, I was young and dumb. I drilled before looking and ended up paying for it, and when I totaled the truck my seat ripped out of the floor.)
