replacing The rear end / differential
#61
Hey Tyler,
Why is the engine running hot? Let's start with that one - there could be lot's of easy solutions or something more fun. There is a pretty quick process to determine if it's a keeper - let's start there & move forward on the overheating problem.
How do the brakes feel to you after you spent some time on them?
How's your son doing in all of this? Did he enjoy helping with the brakes?
Ben in Austin
Ben in Austin
I'll address the engine running hot in another thread. The brakes are already in another thread so I'll answer that there.
My son is enjoying the time he spends on the truck. Unfortunately, that is more limited than my time what with homework, sports etc. He has done a good bit of work, but I need to supervise him and it is hard to both be available to work it at the same time. But we do what we can together...
t
#62
Hey Tyler,
Good to see you are back up to speed on your truck. I couldn't tell if you were going for Highschool beater (but safe) or family heirloom truck for generations. I tried to go with the $15K in between approach & failed miserably - once you get it all apart the list of crap to fix it grows like crazy. I also have a fault of fixing everything if it's not right.
I would make the TCI full frame decision rest on what you end up deciding to do with the front suspension. It's $5K to put a new front suspension on the existing frame - I'd go with the TCI new frame instead of major surgery on the existing frame. If you decide to rebuild the existing straight axle I'd leave the original frame in there & just upgrade the brakes.
Good luck - Keep it fun!
Ben in Austin
Ben in Austin
#63
Hey Tyler,
Ben in Austin
Ben in Austin
t
#64
Just to wrap this thread up, or nearly so, I bought a 9" ford rear end with a 3.00 in it. That will be going in this month along with the new MII front end with power steering and disc brakes. I am having Pete Macey at the Old Ford Store in Tucson put the cross members in and do all the welding. My son and I are doing the rest.
t
t
Wayne Waldrep
31
12-22-2013 05:15 AM
Fordzilla80
05-22-2010 12:23 AM
dick1950
02-09-2008 04:21 AM
