Chassis Swap 1972 onto a 2002
#198
Bumpin' cuz we want an update...
great work , cant wait to see it finished
Criminy, this build can't be more than 40 miles from me here in Benton City. Wouldn't mind swinging by to check it out.
Dan
Dan
Thanks Guys
#199
I had an old parts hood that had a bunch of dents and rust and I was cleaning out the part shed so it was time for it to go. before I tossed it I pulled the "FORD" emblems off the front and almost left the side badges as they looked really faded and were so dirty that I didn't think they were any good. But I pulled them and cleaned them up just to make sure and after a quick paint job on one I was sure glad I did as they look great and will be going on my truck when it's done...
#200
Great build! I have a 83 Flareside that I was in the middle of swapping a 5.0 coyote and 4r70w in until I found my frame is bent. I'm thinking about doing a 83 body on a 03 frame. Both are 2wd single cab short beds. The 70s f100 and 80s f100 frames look similar. Any thoughts on my build before I get started would be greatly appreciated. (I'm hoping my cab bolts will line up with new frame as your front ones did)
#202
Well I never did much research on the 80's chassis as the 2002 kinda fell in my lap and I just went all in on it after I couldn't find anyone who had tried it. The 1997 - 2003 chassis taper at the rear so nothing on the bed lines up and wheel base is another thing to think about. You may have to chop the frame or relocate the rear end to make sure the wheels are in the wheel wells. There is a shop (V8TV) who are also doing the same swap as mine "kinda" short bed 69 (I think) onto a 2003 lighting chassis and they relocated the rear end and lined up everything by moving it forward. (their build is posted on here as well.) You will have to build your own bumper mounts and I'm sure a few other things as you go along but that's to be expected when doing this kind of swap. If I could do it over again the one thing I would do different would be to keep as mush as possible from the vehicle that I got the chassis from, until the project was done. As you go along you can keep it as a reference as to how the factory did it and there might be a simple bolt on fix or another part you need to solve a problem you run into. My project however has been financed by parting out the 2002 so I didn't have much of a chance to think of that until it was too late.
Hope this helps...
Somebody needs to write a novel about this adventure. It is amazing!!
just as long as it's a children's novel. That way it can still have pictures...LOL
#206
#207
Love the project
Wish I could see all of the pics, all I see is a photobucket add where the pic should be!! lol Considering a donor 99 with 5.4 for my 49 F1 project! Just a little Leary of the wiring!
#208
#209
#210
