Wiring diagram for 2003 F350 7.3
Old 09-02-2011, 11:09 PM
Wildfire532FB's Avatar
Wildfire532FB
Wildfire532FB is offline
Looking for a complete wiring diagram for my truck. Ignition switch and everything. Thanks
Old 09-03-2011, 06:20 AM
F350-6's Avatar
F350-6
F350-6 is offline
That's not a diagram, it's a book you're asking for. If you need something specific, we might be able to help you out. If you want the complete wiring schematics, I'd suggest https://www.ford-trucks.com/forums/1...s-members.html
Old 09-03-2011, 08:30 AM
Deluxe06's Avatar
Deluxe06
Deluxe06 is offline
4000 rounds a min
Try this
EBSCOhost - world
user- marshall
P word- public
Old 09-03-2011, 10:24 PM
Wildfire532FB
thats helped a lot thanks man
Old 09-03-2011, 10:43 PM
woodnthings's Avatar
woodnthings
woodnthings is offline
Here is a version I keep on my site. It is for an '02 but should be identical for yours. I have bookmarked it into sections to make use easier.
2002 Wiring Manual- (EDIT) this links to my electrical page now
Old 09-04-2011, 08:10 AM
bfife's Avatar
bfife
bfife is offline
still plays with trucks
Ken's site is the shizzle. I keep it bookmarked in my favorites
Barney
Old 09-04-2011, 09:25 AM
Rose Clifford's Avatar
Rose Clifford
Rose Clifford is offline
careful with the 02 and 03 being the same comment....i think there are some differences such are wire color codes and some options....double check everything you come across before you tap into your pcm wire to steal power for some extra lights!
Old 09-04-2011, 09:50 AM
Larry_the_handyman's Avatar
Larry_the_handyman
Larry_the_handyman is offline
WOW, thanks guys. I was going to buy the wiring manual for my truck, but you just saved me $70.
Old 07-12-2019, 06:13 PM
daveboley's Avatar
daveboley
daveboley is offline
Actually I'm just interested in what wiring and circuitry is fed from that fuse and why the owner's manual does not correctly identify what the fuse actually controls.
Old 07-13-2019, 01:23 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
Welcome to FTE!
I'd suggest starting a new thread with your particular situation so we can focus on it. Necroposting on this thread obscures your needs.
Old 11-07-2020, 05:40 PM
bewildered 7.3's Avatar
bewildered 7.3
bewildered 7.3 is offline
I also have some questions about wiring on my 2003 f350, but none of these 9 year old links work anymore... So, I'm late to the party again. Aft of the battery on the passenger side is a solenoid, appears to be a starter assist relay. on the battery side of this relay, are 2 pair of gray wires, about 14-12ga, always hot. One pair constantly draws .68 amp from my battery, all the time, except occasionally it jumps to over 1 amp, and something whirrs for a second or two. With this disconnected, I have no power to the key switch. I'm considering adding another relay for this circuit, so it is only hot when I turn it on. Is this a normal Ford trick???
airborne0130
02-25-2015 04:53 PM
brandon_wyer
04-10-2007 07:49 PM
duner525
08-26-2004 05:41 AM
mohavi
03-22-2004 11:53 PM
rkm1003
Electrical Systems/Wiring
10-19-2003 08:20 PM
Quick Reply: Wiring diagram for 2003 F350 7.3
