Please help me .. from propne to gasoline
Old 08-20-2011, 01:59 AM
pwright0001's Avatar
pwright0001
pwright0001 is offline
Thumbs up Please help me .. from propne to gasoline
I have a 1995 F-700 with 7.0L propane engine from factory. i need to know what I have to do to switch it to burn gasoline. The truck runs great as it is but I can only go about 22 miles on a 20 lb. bottle. I know that because I ran out 3 times bringing it home the night I bought it. My gps system showed my route was 66 miles. also Will the high compression of this engine be a problem with regular gas ??
Old 08-20-2011, 02:03 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Why do you have a 20lb tank??? The main tank should be at least a 200lb tank? Is it missing? To convert it well you will need the entire EFI setup and a new fuel tank. The comp ratio of the engine is the same as gas.
Old 08-20-2011, 02:24 AM
pwright0001
I have a larger bottle that came with the truck. I didnt know if a carrburator could be put on it . did not know it was fuel injection. thanks
Old 08-20-2011, 12:21 PM
pwright0001
i have looked at system on truck seems to be impco 425 and the piece that mounts behind it has model b printed on it
mapu
13
02-05-2013 04:11 PM
jmm
09-14-2011 02:11 PM
pjlandry
Alternative Fuels, Hybrids & Mileage
02-02-2007 09:56 AM
pullonthis21
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
07-22-2006 03:24 PM
CAT_man_963
02-20-2004 09:21 PM
Quick Reply: Please help me .. from propne to gasoline
