1995 E350 7.3 DI turbo turbo, no power, stalls at normal operating temp
#169
Grrr
I replaced all of the hoses, and the power steering pump.
Weeks later, the leak is back, smaller but still there.
It is NOT the steering gearbox.
(LIGHT BULB)
It must be the power steering cooler.
OK, now I need to remove and pressure test it to find the leak.
50/50 odds it is corrosion or road debris damage.
#170
i'm almost positive what the problem is ..... ... been there done that ... the IPR valve rubber / seal is bad and when cold it wil start if your lucky ( holding pressure ) when it gets warm it wont hold pressure, no pressure, no fire ...... needs to generate up to 3800 psi to fire injectors .... if the damn wiring & fuel filter body wasnt in the way it would take about 15 mins to replace a 5.00 part .... but i needed to pull the fuel filter bowel out to get ate big bolt on back of HPOP ..;... screws out replace seal screw back in ...voila
#172
FYI
For various reasons, it only has a few thousand miles since the seals where replaced.
#173
Racking fracking TOAD
OK, I am officially annoyed.
(LIGHT BULB)
(LIGHT BULB)
Tested the old cooler to 100 PSI air (under water) with no leak.
Stuck the old cooler in a vice loaded with oil and capped, next day my drain pan has most of the oil, and the cooler is almost empty.
Out of curiosity I may waste more time later locating this phantom leak on the failed part.
#174
Grr
I replaced the power steering cooler.
At this point, I plan to remove the total system again, including the steering gearbox for individual bench testing.
My best estimation is three days for removal, fabricating, testing, diagnosis.
This is the most interesting and frustrating passive leak I have dealt with in many years that has become a personal / professional challenge.
I may pickup / install a complete (low mile) replacement system from the salvage yard, to keep the van on the road.
Bigmike540
07-07-2019 10:04 AM
ktorepair
07-15-2016 10:47 AM
e350daBeast
07-14-2014 02:28 PM
robinfite
15
09-06-2006 02:26 PM
