2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Tires I have had great results with on stock rims
Old 08-14-2011, 06:23 PM
Alligator06's Avatar
Alligator06
Alligator06 is offline
Smile Tires I have had great results with on stock rims
On my 06 Nav with the stock chrome 18" rims I used the NITTO Crosstek Light truck tire ( semi-aggressive tread ) 275/65/18 ( listed optional size ) the light truck version tire gives an added ply to the sidewall ( total of 8 plies ) and increases ridgedness to structure to increase the load range to 3200 lb per tire as compared to the stock 255/70/18 passenger tire with load range of 2400 lb per tire . These ride great and stiffen up the truck a bit to give more control feeling .
Old 08-15-2011, 02:17 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
Any advice for 17" highway tires that also have good traction in snow?
Old 08-15-2011, 02:59 PM
Alligator06
From what I read : stay away from Goodyear wrangler sra - many people used wrangler SR-A and said snow traction not good - goodrich was highly praised ; Hancook durapro got great reviews - pirelli scorpions did poorly on snow
Old 08-16-2011, 03:28 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Wrangler Silent Armour, Wrangler Duratrac
2 great, no awesome tires. Silent Armour isn't a very aggressive tread wise, but has excellent street/dirt traction
The Duratrac is a much meatier tire. I'm hoping to install those on my Expy in October. Very aggressive tread and they work excellently offroad in the mud/snow
Originally Posted by Alligator06
wrangler SR-A
that is the factory tire for many SUV's and small trucks
absolutely worthless excuse for a tire. I cannot say a single good thing about the SRA
Old 08-16-2011, 10:04 AM
MCDavis's Avatar
MCDavis
MCDavis is offline
You may want to check out the Michelin LTX M/S2. It's a great highway tire and the snow traction is superb. I have them on my F150 and I'm extremely pleased. They are quiet, smooth, roll forever, and the wet and snow traction is quite good.
I will warn you, they are a bit pricey, but worth their weight in gold. This is my 4th set of Michelins on 3 different vehicles.
Old 08-16-2011, 07:03 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
ok I will check into tires in september I think. only 2 need replacement, the other 2 I dislike as they are pathfinders AT something from discounttires (from previous owner), really loud but too new to ditch.
Old 08-16-2011, 07:43 PM
heterodox1's Avatar
heterodox1
heterodox1 is offline
Talking
I ran the BFG All-Terrain T/A KO (285/70-17) on my 2000 Exp. These tires did very well in the snow and I had 100,000 miles on them when I sold the truck. I'll bet they had another 10-15K left on them! I recommend these.
Old 08-17-2011, 09:55 PM
TCAS007's Avatar
TCAS007
TCAS007 is offline
Is it ok to replace the 2 more worn tires only or do I have to go for 4?
Asking because I read that it may cause damage otherwise..
Old 08-18-2011, 01:59 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
make sure they are all the exact same size. If you are running 2 different brands, try to get them with nearly the same tread depth.
also, run them in pairs (fronts, or rears only).
you won't cause any damage if you do the above. I've been doing it for years. I'm a fan of only doing 2 tires at a time. Saves a little cash...and with my driving style, I typically replace the rears alot . Then put the new tires up front (steering important to me) and older tires out back
the biggest thing to remember is that you have all 4 tires that are the same overall diameter. This will prevent ABS problems. On my Mustang, I ran staggered width tires, but the diameter was the same...car didn't know any better
Old 08-18-2011, 09:05 PM
Boomer1956's Avatar
Boomer1956
Boomer1956 is offline
Doesn't that logic fail the first time you rotate, you will end up with the tires on different corners you started with.
Old 08-18-2011, 09:22 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I personally don't rotate with the "Z" pattern. Most of my vehicles have had a LS in the diff, so tire wear is essentially identical. It's worked great so far for me. That and I usually also run directional tires, so the "Z" can't be used regardless
I just swap the fronts and rears and call it a day
Jimmy Dean
1999 to 2016 Super Duty
17
02-08-2014 09:42 AM
lundman
6.7L Power Stroke Diesel
07-23-2012 08:57 AM
PHS79
2004 - 2008 F150
22
03-01-2006 09:11 AM
78bigbronco
1997 - 2003 F150
09-12-2005 08:54 AM
Dog_Brains
08-30-2001 09:16 PM
Quick Reply: Tires I have had great results with on stock rims
