The Ultimate Showdown! (6.2L vs Comparably Equipped Ecoboost F-150) ''Drag Race Clips''
#32
#33
Things get broken when drag racing modified trucks who are putting out more power than stock. Because the driveline is designed around the stock power levels it can get overwhelmed and break with higher output caused by engine mods.
#34
2. Why would there be a warranty issue with the dealer? The warranty is definitely still good no matter how many times you go WOT or 120mph.
You could take your truck and drive it like they did in the EcoBoost torture videos if you want (WOT for 24 hours with 11,300 lbs. towed), and as long as you change your oil when necessary, you're covered.
#35
On the subject of WoT runs and if it will or will not damage the Powertrain/Drivetrain.
Well in a new stock truck, I think the chance's are highly unlikely that you would see any damange from an empty WoT run. You could probably drag race a stock truck down a 1/4 mile track 7 days a week for a year and not see any damage...''Assuming you don't do anything stupid like netural drops''.
But yeah I would say all these new engines have pretty much been tested to the same extent that the Ecoboost has. The Ecoboost's testing was just made more public because it was the engine that had something to prove. Ford know's that some people are gonna race these trucks...They know that some people are gonna tow a ton of weight with them...And a brave/dumb few are going to even exceed what these trucks are rated at for max towing. Make no mistake, If Ford didn't feel confident in their new engines they would not have relesed them to the public. The last thing Ford wants is to get bad <acronym title="Page Ranking">PR</acronym> because a bunch of kids blow's their engines red light racing.
With that said I pretty much never run my truck at full throttle. I know that my 5.0L could probably handle revving close to the redline all day long and be just fine...But I'm not one to risk it. The only time's I ever go full throttle ''in any of my vehicles'' is if its an emergency manuver and I need to get the hell outta the way and fast!
(On a side note)
I have heard that doing a full throttle run ''perhaps onto the highway onramp or something'' ever now then is actually good for you're engine? Supposedly the higher RPM's and all that help to clean carbon depsoites outta you're engine? Has anyone else heard of this? If it would be interesting to try and debunk it here.
(On a side note)
#36
Every vehicle I own sees redline nearly every time it gets driven. Including my 11-year-old contour...that old V6 sees 7,000 RPMs daily. It's maintained well though, and still going strong. I have never met anyone who blew a stock engine by letting it rev, and I have a heck of a lot of fun doing it. My motorcycle is also out of warranty, and revs to 11,000 RPMs. GREAT stuff!
#37
Oh I do frequently!
#38
In the mtns I'm pretty sure people destroy trans because they fear RPM. Just let the freakin motor work people! Instead its floor it to get to 55mph, then panic cause its in 2nd gear, so let off and let it shift to 3rd, then when it won't hold speed, floor it to get back to 55mph in 2nd gear, then let off, etc. They'll do this 20 times up an 11 mile pass. Yikes!
#39
But I imagine within the next 15 to 20 years Manumatic Transmissions will most likely be standerd on every make and model of car and truck. Manumatic meaing that if you so choose you can drive it like a Clutchless Manual Transmission, or just let it do its own shifting like any other Automatic. Which should eleminate the whole gear hunt/mountain issue.
Last summer I took a trip threw the mountains of New Mexico in a ''Rental'' Suburban, it had a 6-speed auto with Manumatic function, and the only way I could get enough power to make that fat pig haul its sorry *** up those mountains was to shift it manually, and you better beleive that thing spent the greater half of that trip bouncing off the Red-Line. ''I'm nice to my and others personal vehicles but put me in a rental and you better get the hell outta the way!'' In my experience that GM 5.3L is one gutless turd...But that's a whole nother article right there...
#40
on
No offense to any Italians present
#41
1. Why would something break? You think trucks aren't supposed to go WOT or reach higher speeds (which they were built to do)?
IB Nolan
Newsletter Archive
02-12-2018 06:13 PM
640 CI Aluminum FORD
Ford vs The Competition
12-10-2014 10:35 AM
ocasio0727
15
05-12-2014 06:36 PM
