wiring complete/ not firing
#31
A couple more carb thoughts
After the top is off, if you can simply reach in and lift the float(s) out of bowl, the problem is found, because the wire(s) wasnt secured into seat groove.
Be careful not to drop or lose needle, as it dangles from float, hanging on a small clip.
When replacing top make sure the gasket is on correctly. Dont overtighten and strip screws. Watch that the small piece of plastic on the choke lever/rod is properly in place and doesnt get jambed between top and body (sometimes the plastic piece is missing).
#32
46 you were right, I hadn't secured the needles properly...now it runs on its own...WOW! what an awesome roar a Y block screams with straight pipes!!!Its sooo, good to know the carb is functioning well...I will adjust the idel tomorrow...wow, such a long time getting here!...I'll send a video soon...
Mister_King
10-27-2014 12:40 PM
black58
35
11-22-2010 11:43 AM
streetrodcreed
03-24-2006 01:10 PM
