They will fit with a little header panel modification. Use the search and you will find all you care to learn about the process. I have the 02-04 that bolt directly in
Good luck
The 05 headlights are deeper. I used a cut off wheel on a air powered die grinder to modify the header panel, it took about 10 minutes. the bulbs need plug adapters for the different bulbs too.
