look what I found in my coolant filter!
Also if the coolant and oil get mixed in the oil cooler you will have cross contamination regardless of the difference in pressure.
My first filter was pretty gooey after three months.
Welcome to guzzle's Coolant Bypass Filter Mod Web Page
And here is a kit for ya
http://www.dieselsite.com/1994-19977...ionsystem.aspx
For what it's worth, I mounted mine in a different place than most do.
See: http://springerpop.net/F350/coolant_bypass.html
Pop
Pop
It looks like the oil cooler was the issue, the original o rings where hard as plastic and I could see on the filter head side where the oil was pushing past the small ring. All that is left to do is run in to town in a few hours and try and find some ELC and a new t stat.
I'm not going to run a blackstone,I'm pretty sure there is/was at least trace coolant in the oil, I'll just change the oil and coolant filter again( I changed it when I did the cooler) in another 500 miles. Delo is up to $17 a gallon here so by next Monday I will have spent $240 in oil changes
#29
#30
I know what you mean Steve. I had just changed my oil a few hundred miles before I noticed there was oil in the degas bottle. New oil, filter and ELC. It sure adds up.
