Got the 1956 f-600 running. Now I need a fuel pump for the 272Y block is there another fuel pump that will bolt up. Or will I have to go with a eletric pump
292 was around in 56 and a engine that could be found accross ford and merc's
312 was more or less a car enigne on the high line's in 56.
not sure if it will work but like I said worth looking in to.
