6.2L V8 Discuss the 6.2L V8
RP or AMS OIL
Old 07-31-2011, 11:00 AM
tolliewolly's Avatar
tolliewolly
tolliewolly is offline
RP or AMS OIL
I'm going to run one of the two oils. I'm leaning towards royal purple since it's down the street at oreily for the same price as mobil one. After it gets 3000 miles on the new motor I am going to switch it to royal purple or AMS.
Thoughts?
Old 08-01-2011, 06:29 AM
Strokt350d's Avatar
Strokt350d
Strokt350d is offline
Use Ford Semi-Synthetic, change it every 4,000 miles or so. Best $24 you could spend. I am an Amsoil dealer, but always recommend changing the oil more frequent. I have plenty of good stories of guys that religiously change oil every 3k-4k. Matter of fact, Amsoil has a bulletin out recommending that 6.4 owners NOT listen to manufactures spec on oil changes (that's 7,500).
So, my vote is the $24 Walmart Ford Semi Synthetic oil change at like 2/3 the frequency that Ford recommends.
Old 08-01-2011, 08:03 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
It's not a really scientific opinion, but I am not impressed with Royal Purple versus Mobil 1.
And it has nothing to do with engine oil, but I will explain:
The rear in my '01 had a slight whine on the highway, did it brand-new, under very low load, almost coasting. Did it for years. One day, I decided it was time to paint the diff cover otherwise it was going to rust through.
Removed, painted, reinstalled. Only synthetic 75w140 I could find locally was RP at the time. So, in it went.
The whine was still there, no change.
Cover developed a leak (my own fault) so I had to pull it again. Figured, try Mobil 1 this time.
Whine is GONE, and has been for 5 years.
This shadetree mechanic isn't going near RP ever again.
Either use the Ford stuff, or go with Mobil 1.
Old 08-01-2011, 08:46 PM
Super08's Avatar
Super08
Super08 is offline
I second that.
Old 08-09-2011, 01:46 PM
Buckholz's Avatar
Buckholz
Buckholz is offline
Pennzoil Platinum is my personal choice. Do some searching on the web about Pennzoil Platinum oil..... read Bob the oil guy forums.......
Batman7777
1999 to 2016 Super Duty
20
08-20-2018 06:40 AM
wayde
6.7L Power Stroke Diesel
02-11-2012 12:06 PM
MikeJ2003
1997 - 2003 F150
07-18-2009 09:43 PM
Eu07
Oil & Lubrication
02-14-2005 12:17 AM
Critterhunter
1983 - 2012 Ranger & B-Series
09-19-2002 03:40 PM
Quick Reply: RP or AMS OIL
