1965 F100 parking brake assembly
I would check with Dan's Ford truck parts. He parts out a lot of trucks and has a good variety of parts for sale.
dansfordtruckparts Dans Ford Trucks Dan's truck's items - Get great deals on items on eBay Stores!
Applications: 1965/66 F100/250 / 1965/66 F350 w/T-87 H/D 3 speed manual or MX Cruise-O-Matic only.
C5TZ-2A635-D .. Right Rear Parking Brake Cable-61" long-from equalizer to rear wheel / Obsolete
C5TZ-2A635-C .. Left Rear Parking Brake Cable-55" long-from equalizer to rear wheel / Obsolete
Applications: 1965/66 F100 2WD.
C5TZ-2853-P .. Front Parking Brake Cable-98" long-from control to equalizer / Obsolete
Applications: 1965 F100/250 2WD / 1966 F100 2WD w/o Power Steering / 1966 F250 2WD.
NOTE: The 129" wheelbase trucks also use two 14" extensions (C5TZ-2A793-A).
What's wrong with yours? Is the handle broken, or when you pull the handle/shaft out, it doesn't engage?
C5TZ-2780-A .. Park Brake Control Assembly / Obsolete / AFAIK, not reproduced / ONE available NOS
Applications: 1965/66 F100/250 2WD / 1965/66 F350 with MX Cruise-O-Matic or T-87 3 Speed Manual Trans.
But, the handle was replaceable, as was the curly-Q spring (OM-2788), its associated parking lever pawl (OM-2788) and the pin (OM-2788) that fits on the end of the shaft to lock it in place when the handle/shaft is pulled out.
Usually the spring breaks and/or the pin falls out. These parts are obsolete, but date back to 1950, were used on a gazillion cars/trucks, so prolly can be found NOS
Originally Posted by ZombieSlayer
Any chance of getting a part # for the equalizer?
The cable's adjusting rod (2628) attaches to the lever, then to the equalizer bar (2A602) that the two rear cables attach to.
These are basic numbers only, will type the full part number(s) when I know what you need.
on
parking brake nos in ohio, and king pin bushes help
Hi i found this nos stock one (i don"t need it at the moment),Here are the details below.I would buy it for stock,I may need it one day,let me know if you dont want it and i will enquire about payment and shipping to auckalnd,nz just to put in my growing mountain of NOS parts,ps has anybody got any brass kingpin bushes for my 65 F250(camper special ranger),i got plastic ones with the king pins but would like NOS ,I did actually buy nos from a ford parts dealer in the usa but when they arrived they where plastic,advertised as genuine, oh well wont go there again.
<table class="headers-table" summary="Message headers" cellpadding="2" cellspacing="0"><tbody><tr><td colspan="2" class="more-headers show-headers">
</td></tr> </tbody></table> HELLO GARY ,
WE DO HAVE C5TZ2780C , PRICE IS $160.00 PLUS SHIPPING
THANK YOU
DARRELL
GREEN SALES COMPANY
2172 SEYMOUR AVE
CINCINNATI OH 45237
TOLL FREE: 800-543-4959
LOCAL: 513-731-3304
FAX: 513-731-4775
THANK YOU
DARRELL
GREEN SALES COMPANY
2172 SEYMOUR AVE
CINCINNATI OH 45237
LOCAL: 513-731-3304
FAX: 513-731-4775
C5TZ-2780-C .. Park Brake Control-Orscheln Lever type-Mounts on floor / Obsolete
Applications: 1965/66 B500/750 (B = School Bus) / 1965/66 F500/750 / 1967/69 T800 (Cummins Diesel) / 1967/72 F700/750 Chassis & Cowl (Open Drive-Away).
If you have one of these trucks, this is the part you want. But, if you have a 1965/66 F100/250 2WD, it's obviously not correct!
Both posts #6 and #8 have the following info: C5TZ-2780-A .. PARK BRAKE CONTROL / OBSOLETE
ONE available NOS, but Green Sales doesn't have it.
4) C9TZ-3110-A .. Bronze (not brass) King Pin Bushing / Obsolete
Found 16: 11 available from 6 FoMoCo Dealers / 5 available from 2 obsolete parts vendors.
No FoMoCo Dealer has more than 2, no obsolete parts vendor has more than 3.
The front park brake cable connects to the equalizer lever (2A605) that mounts to the crossmember using a separate bracket (2631).
Budget currently doesn't allow work to progress on the truck, so I'm in no hurry getting the info
I need everything from a to z, complete handle assembly, all cables (can get from Napa), and all of those little parts you gave the basic #s for. Previous owner ripped it out who knows how long ago
This wouldn't be the first time this has occurred. By the time one fellow got around to buying some obsolete hoses I listed (12 were available), only 2 were left when he finally got around to calling the source.
Coupla years ago, I listed the sources for the 1961/66 lighter **** & element (C1TZ-15052-A)...28 were available. How many are available now? TWO!
