Truck died on freeway
Two days ago my truck died on the way to work. It would just crank and crank so here I am figuring it's the stupid fuel pump again. So I check the fuel rail, voila there is pressure. After work and driving my mustang I come back, stick the key in...fires right up. Then today I go out to start it and nothing. Power comes on, fuel pump primes, doesn't even kick. On the 4th turn of the ignition it starts. What could this be? While my motor is being built in my Bullitt I have to drive this stinking thing lol.
I'm thinking your right on. I wiggle the connection and bang on the coil and it starts so that may be the problem. Funny thing is, I had an engine put in about 1000 miles ago and got a CEL every so often with some engine hesitation and twice it just shut down on me. On the way home from the beach, it came on again but instead of stopping the truck and restarting it, I just kept rolling. I went to pass a truck and it shook the whole truck like 3 times and I thought it was going to quit but the CEL went out and it took off and smoothed out. Since then however, I haven't had a CEL in 2 weeks but now it does this where it won't start.
on
I have to agree with this one too, even though the coil is a good candidate and worth looking into.
When I bought my truck, it ran great, and I drove it all over. Then one day I came out of a fast food joint and started it, and it died. I started it again, and it ran great, so I backed out of the parking spot and it died again. I ended up having to hold the key a little bit toward start all the way home.
On further inspection, the ignition switch was bad. When I took it off the column to replace it, it fell into parts in my hand. I couldn't believe it had worked to get me home!
Once I put the new one in, it was fine (until my fuel pump on the frame let me down a few days later).
Yeah I'm getting an MSD coil cap and rotor. I already have some 8mm wires to complete what I need to do the ignition timing upgrade.
Right now I am thinking I am having an ignition switch problem. I bought a new fuel pressure regulator but the one on the truck looks new. I bought all new dist cap (with the brass terminals) and spark plugs, wires are still good. I am getting my Bullitt torn down for a 5.0 stroker next week so I need this truck to run.
