clutch problem
DITTO!!
I'm having the same issue with mine...and like yours, the slave cylinder was supposedly replaced shortly before I bought it. I have heard that this can happen if the hydraulic line is not properly connected to the slave cylinder...something about the connector being a pain to get on right.That is my next project, so I would be very interested to know if it can be resolved without removing the transmission. I took out the inspection plug and looked at the slave cylinder with a flashlight...it does indeed look pretty new.I am definitely interested in knowing if this is common with some replacement slave cylinders, so I will know what to avoid if I have to get a new one.
common problem , these slaves are notorious for failing , you'll probably see the fluid oozing from the part of the slave that mounts to the transmission.
Thats why all of us get so good at pulling the tranny on these trucks. If you have any doubts on the clutch itself replace it while you have the tranny out because Murphy will usually trash your clutch about 4 weeks after you replace the slave.
What would be nice is a kit that allows you to change from the concentric internal style combination slave cylinder and release bearing to an external style slave with a release fork as used on the big bell ZFs and the 4 speeds. Anyone tried this? Sure would make things easier, and probably save some clutch assemblies and/or transmissions!!
I am going over to the Ford dealer tomorrow to check on some center cap retainers, and while I am there I will see if 1.) I can even get a new slave cylinder from them...and 2.) find out how much it will cost me. *shudders*
FordOwnerJoey
02-26-2014 02:30 PM
cinbearcat
Escape & Escape Hybrid
11-30-2013 05:52 PM
Eallend7
02-05-2013 06:31 PM
89nolaf250
01-31-2010 01:37 PM
