New guy here
The obvious is to have the A/C serviced. At least needs a charge unless something else it faulty.
For keyless entry you need to fit both doors with actuators, inside control on the arm rests and the receiver plus a hand transmitter and figure out the harness integration.
I believe you will need to address the use of the GEM module unless you make it a stand alone job.
Get all the hardware form donor truck in a yard.
My opinion is it's not worth the hassle unless you make it from after market simpler hardware.
Good luck.
Good luck.
Bankrupter
41
10-29-2011 12:20 AM
