1952 FORD f1 PICKUP
1952 FORD f1 PICKUP
Year: 1952
Make: Ford
Model: F-Series Pickup
Price: $13000
Mileage: 57000
Color: Gray
Private or Dealer Listing: Private Listing
Location (State): TX
Transmission: Manual
Drivetrain: Rear Wheel Drive
Color: Gray
Engine: 239 flathead
This is a 1952 F1 Ford pickup with the original flathead eight 239ci engine in it. It has a three speed shift on the column. It runs well and has had a lot of new parts put on the truck. The truck is all steel with a couple places that need to be fixed. The truck has original paint job that needs to be redone. I am asking $ 13,000 for the truck. The window on driver’s side has a BB shot in it and the passenger’s side is cracked but they work well and can be replaced for 80.00. It could be a daily driver as the truck drives well on the road. Here is the list of things I have done to the truck. I have the old carb and fuel pump, long horns and some other little parts you can have to rebuild or trash. I have a 9” ford rear-end that is a 370 that goes with the truck and a few extra parts that go with it also. I must be paid in full and must clear bank before truck is picked up. Cash will talk. I will not deal with a third part such as an agent. You must arrange for pickup or delivery from my address to your. You pay for transportation of the truck.
New 12 volt wiring harness New sun visors installed
New shoulder seat belts added New Water temp sending units
New king pins installed Turn signals added
New belts New fan shroud added
New under engine pan New pitman arm
New wood in bed All lights have been changed to 12 volts
New cowl to hood seal New drag link and parts
New Thermostats both sides New Thermostat housings
Dual exhaust pipes New fuel pump
New carburetor New fuel line and filter
New temp gauge New Horns
New tie rod ends New center tie rod link
New ignition coil Flame Thrower epoxy filled
Radiator has been taken to shop and rotted out
New Oil pressure sending unit
Gas tank has been cleaned inside and out
New gas sending unit New windshield wipers and arms
