Rear view camera - random problem
Old 07-10-2011, 11:01 PM
DrewF's Avatar
DrewF
DrewF is offline
I picked up my new truck last Friday, and already the rear view camera is having a problem.
Sometimes it comes on, and is all fuzzy and black and white.
Other times, it comes up solid blue, then the display goes off.
Guess I'll be making my first trip to the dealer.....but it wont be the selling dealer, as they are about 70 minutes away.
Anyone else had this issue? I did a quick search, and nothing came up.
Old 07-10-2011, 11:36 PM
nebmike's Avatar
nebmike
nebmike is offline
I've had mine about six weeks now, and have experienced the same exact thing. In addition, I've had times where it wouldnt shut off when going from reverse to drive -- it would stay on until I shifted into park.
I'm not too concerned about it, so I'll just wait until I need to be at the dealership for something else...
Old 07-11-2011, 07:22 AM
kper05's Avatar
kper05
kper05 is offline
Best option is to visit your dealer for this one.
Also if you're concerned about whether or not you'll be able to reproduce the issue at the dealer, take a video of what happens so you'll have that if you need it.
Old 07-11-2011, 07:26 AM
DrewF's Avatar
DrewF
DrewF is offline
Yeah, I have already taken photo documentation of the issue. This way the dealer tech knows I am not making things up.
Old 07-11-2011, 02:01 PM
doczenith1's Avatar
doczenith1
doczenith1 is offline
Mine has done the b/w fuzzy a few times as well. Seems like it happens when its hot out and the camera has been in direct sunlight for a while. Out of curiosity, do you guys have the NAV system or standard radio? I have the standard radio.
Old 07-11-2011, 02:19 PM
DrewF's Avatar
DrewF
DrewF is offline
I have the standard radio too.
Old 07-11-2011, 03:12 PM
nebmike's Avatar
nebmike
nebmike is offline
Same here.
Old 07-11-2011, 07:05 PM
carpbob's Avatar
carpbob
carpbob is offline
Have you taken the tailgate off for line-x or anything? If so check the plug.
Old 07-11-2011, 07:21 PM
DrewF's Avatar
DrewF
DrewF is offline
Not yet. I'll probably check the plug. It seems to work after I open/close the tailgate. I checked the wire where it comes out of the bed and into the tailgate, but it looks fine.
Old 07-11-2011, 08:56 PM
Double-Trouble's Avatar
Double-Trouble
Double-Trouble is offline
I would take the cover off the tailgate and check for a loose ground. If I didn't want to take it to the dealer.
Old 07-18-2011, 08:14 PM
cabindoc's Avatar
cabindoc
cabindoc is offline
You might also try taking the radio out and check the connection to the back of the radio.
Old 07-19-2011, 05:18 PM
grantschim's Avatar
grantschim
grantschim is offline
I've had my 2011 for several months and the rear-view camera has worked flawlessly. I have the Nav System.
Old 07-19-2011, 05:50 PM
2horses's Avatar
2horses
2horses is offline
Mine has been flawless with the NAV system - maybe it's more of a display issue than a camera issue? Since all of y'all that are having the same problem have the same rear view mirror display, it could be the problem instead. Maybe it's heat related.
Old 07-19-2011, 07:08 PM
lkbrow1's Avatar
lkbrow1
lkbrow1 is offline
The wiring to the camera video is a coax cable. Right before the plug that allows you to disconnect the tailgate the coax is spliced back to regular wires that go into the connector. You could have an intermittent connection there. If the video signal is weak the display will remain blue until it times out then goes blank. If a video signal is strong enough, the camera stays on after shifting into drive until you reach a minimum speed. I can back out of my drive way, pull up to my mail box, read a letter, and the camera will stay on until I leave the mail box.
I removed my tailgate and connected a camera to the harness that was in a license plate holder.
that's how I got so familiar with the functionality.
Old 07-19-2011, 10:50 PM
Painted Horse's Avatar
Painted Horse
Painted Horse is offline
Received 2,606 Likes on 739 Posts
"I removed my tailgate and connected a camera to the harness that was in a license plate holder. that's how I got so familiar with the functionality."
Did your license plate camera plug into the harness or did you do a splice. I've been wanting to add a camera on the back of my trailer for when I back into dark spots when days get shorter.
Quick Reply: Rear view camera - random problem
