Lots of '73-'79 Parts - Parting out 2 1979 F350's
#391
Category: Accessories
Price: $20
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Prelude, FCX
Item Condition: PA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck
#394
Everyone, here is the current list:
I ONLY have what is on the list below!
Everything on this list is current and available:
No beds, sorry.
Sorry I don't, unfortunately FTE will no longer let me edit the list on the first page. See list above for current list, up to date.
I will pack this up and ship it out to you. The price on the window is $100 and it is in great shape. I am going to let you get the quote for shipping, however. It will be dimensions dependent (add 4" to every dimension for the packing), not weight dependent so just throw in 25lbs or something - it won't matter. I use fedex, just use their website..my zip is 18078, dropoff at a local fedex location..if you're still interested, we can get it done.
- Good 11" clutch used with 400 motor but originally from 351m
- Front Dana 60 gears, carrier, cover (NO HOUSINGS OR COMPLETE AXLES, see other ads)
- 31"x10.50x16.5 used tires and wheels (3 left, 1 is new unmounted)
- NEW ignition parts (almost the entire ignition, coil, relay, distributor etc)
- transmission cooler and radiator
- auto transmission linkage from column
- NP205 transfer case shifter, shifter k n o b and chrome trim around shifter boot (NO cases or 4wd shifter boots)
- Speedo cable
- Manual steering column complete with levers
- Steering shaft
- Steering wheel
- Front CV driveshafts
- Rear driveshafts
- 75A High Output Motorcraft alternator!
- transfer case heat shield from snowfighter
- transfer case sandwich frame mount
- front grill mount brackets (3) and all hardware
- 3-piece transmission/transfer case crossmember complete with hardware
- rear f-250 snowfighter leaf springs
- front dana 60 u-bolt brackets (only the top brackets available, no molded lower brackets rear dana 60 u-bolt brackets
- Rear Leaf spring blocks
- Rear Leaf spring blocks with bumpstops
- throttle kickdown rod with c-clips for auto trans
- Rear glass with sliding windows complete (with good rubber)
- EXCELLENT condition
- front radiator core support/front bumper/fender support
- Rare 100MPH Black-background gauge cluster in great shape
- Silver guage clusters (2 different ones from F-350's in great shape)
- Ignitions with keys
- Hood hinges, mounting tracks
- Tailgate hinges
- Left tail light
- Upper and lower door hinges
- White glove door
- Red, white, blue or black ash trays, original cigarette lighters
- Chrome door pulls
- Plastic door lock pulls
- Window cranks with black or clear plastic k n o b s
- F-250 Custom badges
- F-250 Ranger badges
- F-350 Custom badges
- XLT badges
#395
Freight's ~$60 to 95648. Will I need to get a new set of rubber and trim? What's your preferred payment method? I'm okay to send you a check and wait for you to cash it before shipping. No PayPal. Not in a super hurry but just got this truck and want the slider at some point. This seems like a pretty good deal. Let me know, thanks!
#397
79.38
Nope, sorry. I doubled checked and I do not have any.
#398
I know its long shot but do you have the thin chrome trim for an 8' box
I am not looking for the wide stuff with the rubber insert. thanks
if you dont have it maybe you know someone that does or mabey someone else looking at your post.
#400
I have no idea. I do know the plastic behind the "horn" is cracked and slightly broken.
