A/C wont change from defrost
I have a 2005 ford excursion limited, 4X4 diesel. When I turn the A/C on it will only blow through the defrost vents (windshield and front windows). I push the other buttons to change the flow and get no response. I hear there is a vacuum actuater under the dash, any ideas
You have a vacuum leak (95% likely) or a bad air blender (5% likely) Most common spots for vacuum leaks #1 somewhere in the 4WD lines. #2 whatever lines are exposed to the most heat or vibration. That may sound like generic advice but that's how it is, vacuum leaks are tied for the most irratating problem to figure out, oh yeah, electrical gremlins are the other tough one.
jstihl
17
01-18-2016 09:25 AM
99exp4wd5.4l
1997-2006 Expedition & Navigator
06-16-2012 04:52 AM
RollTideRoll
1999 to 2016 Super Duty
05-22-2011 03:33 PM
dep295
08-06-2008 06:11 PM
