Vermont July BS - Independent BS to all!
07-08-2011, 08:32 PM
not unless he does studs the heads first!
07-08-2011, 08:33 PM
VT Chapter Ldr
Have to be a positive displacement one like a Whipple
07-08-2011, 08:35 PM
They don't make them any more, and they really didn't work so well!
07-08-2011, 08:37 PM
VT Chapter Ldr
Definitely. 6.4 is a pretty good engine once the regeneration system is taken off. Then you Can make power and get good mileage.
07-08-2011, 08:39 PM
Get one of those Alton F650 Excursions.....
VT Chapter Ldr
Your not talking about a paxton are you? Those build boost with rpm. I still think a Turbo is it.
07-08-2011, 08:40 PM
VT Chapter Ldr
Be cool but a bitch to park.
07-08-2011, 08:42 PM
Quote:
Originally Posted by
sddesigns
Exactly. 6.0 are famous for lifting the heads on overboost. The brilliant engineers at international decided to put 8 fewer head bolts on them than the 7.3. WTF??
sddesigns
Never seen one.
07-08-2011, 08:43 PM
VT Chapter Ldr
Whats the VB spring swap all about anyways? That must be a few hundred bucks.
07-08-2011, 08:44 PM
it's the V front springs from the F350 and B rear springs from the F250 with a F350 rear block!
07-08-2011, 08:46 PM
Now, that's not the leveling kit, though, Steve. I don't think it is anyway.
07-08-2011, 08:47 PM
VT Chapter Ldr
97nukeford
Never seen one.
The reason they lift the heads also is the EGR gets plugs, then cracks, lets coolant enter the intake, makes it to the combustion chamber, turns to steam, spikes the e cylinder pressure, than pops the head gasket. No over boost needed.
07-08-2011, 08:48 PM
I've had that intake/egr/egr cooler cleaning done once.
07-08-2011, 08:49 PM
97nukeford
it lifts it 2" from stock, but mine is sagging anyways, so it might be about 3" lift all the way around.
I can't fit anything between my front bump stops except maybe a piece of paper.
