96 F150 Check Engine Light Wont Go Out!!
my brothers truck is driving me insane, it keeps setting p0171 system lean and p0174 system lean codes, i have replaced the mass air, checked all over for vacuum leaks, replaced the fuel filter, i did a fuel pressure check and found i had between 30-34psi, so i went and got two new fuel pumps, put them in and ive got the normal 42-45psi of fuel, i cleared the codes and about 40 miles later its popped right back on, anybody got anymore ideas before i pull the bulb out the dash for the check engine light???? this truck runs fine but the light wont go out
the exhaust is new from the converters back, i havent replaced the o2 sensors yet, with the obd II plugged in the o2s appear to be working they constantly change voltage and what not, the truck still has the factory exhaust manifolds there and i put stock walker exhaust on it when i did that, the truck is bone stock no aftermarket parts except for a drop in k&n filter
I was having the same codes on my '96 a couple of months ago, just prior it needing a new inspection sticker, so I put a new O2 sensor on the bank one manifold and it fixed the problem. I found a Bosch sensor on e-bay for $19 with free shipping and had enough time to wait the five or so days it took to get here. I now wish I would have bought all three! It also improved my mpg.
You can try to watch the o2 voltage while under a partial load and see how they react. Typically though a scan tool being digital is probably not quick enough to see the actual fluctuations real time so you may not see anything significant. Usually the only times I have seen a bad o2 with a scan tool it was so bad it never changed.
If we are shooting from the hip and replacing parts my vote is o2 replacement or you have an air injection check valve stuck open and its dumping air into the exhaust all the time.
Dunno
Dunno
WhyFord
1997-2006 Expedition & Navigator
163
02-17-2017 07:49 PM
feo_nuts
1997 - 2003 F150
08-04-2011 09:42 PM
