2WD Front wheel bearings
Might as well replace the grease seals too, since they have to come out anyway. But maybe that was already on your list. How many miles on your "97"? If you don't have a torque wrench to set the bearing pre-load you can do this: To set the wheel bearing torque WITHOUT the torque wrench, just tighten the adjusting nut very snug to seat the inner and outer wheel bearings on the spindle; (making sure they are PACKED with fresh grease first) and then back off on the adjusting NUT until the wheel spins freely with no play in it. Put the nut-lock on and the cotter pin back in and you're set.
I dont know about using ford only bearings, just go to a bearing house and get some good ones along with the seals. will be a lot cheaper, but if you take care of the bearings even those from a parts house will last. I have 300K+ on my 94 and got the bearing at napa or from checkers cant remember! Anyhow the PIA is to change the races if/when you do R&R the bearings.
PaulTMurphy
06-02-2017 05:18 PM
72GTS
06-15-2016 09:23 PM
johnsteffy
09-23-2010 10:21 AM
