Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
OLD DECODES
Old 03-22-2014, 11:43 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by quickfarms
I am looking for the rubber floor mat for a 1989 F800. This is the full cab mat.
With individual seats or a bench seat? What engine does it have?
And...are you sure this is an F800? I've been looking this jazz up in parts catalogs for 42 years, so I know that some people confuse C800's, LN800's with F800's.
1981 thru today: 5th-6th-7th digits of the VIN decode to the specific model and series of truck.
  #152
Old 03-23-2014, 12:11 AM
quickfarms's Avatar
quickfarms
quickfarms is offline
Yes it is a F800, I actually bought it as a parts truck for my FT900, it has a 7.8 and an Allison. It will have buckets in it when we put the replacement cab back on the frame.
I created a photo album of the F800 and named it crusty.
  #153
Old 03-23-2014, 05:57 AM
NumberDummy
I'm still not sure what you want, so here are the choices.
Don't expect, however for any of these mats to be still available...as they're probably obsolete
  #154
Old 03-25-2014, 10:55 PM
Gilc's Avatar
Gilc
Gilc is offline
C8000 gearshift rod ujoints?
I have a 1988 C8000 Vin 1FTYD80U9JVA41661
Help would be greatly appreciated in locating two of the:
"JOINT ASY. (TRANSMISSION GEARSHIFT CONTROL ROD
Part #: C8HZ7B170B"
It seems to be obsolete from Ford's part distribution.
Is a substitute replacement part known?
I'm hoping to get the parts first before disassembling, otherwise I will have to take it apart and measure, then search for something that fits.
Thanks in advance.
Gil
  #155
Old 03-26-2014, 01:51 AM
NumberDummy
"JOINT ASY. (TRANSMISSION GEARSHIFT CONTROL ROD Part #: C8HZ7B170B
Obsolete ~ No Ford Dealer or obsolete parts vendor has any.
  #156
Old 03-26-2014, 08:42 PM
quickfarms's Avatar
quickfarms
When we did the last truck I purchased a new floor mat in 2011. The part number was F1HZ*6013010*CAJ.
On this truck which is identical to the first truck, as far as the floor goes. We ordered the same mat for this truck but the warehouse could not find it even though it showed one in stock. We still need this mat. Any ideas on alternate sources?
  #157
Old 03-26-2014, 11:26 PM
NumberDummy
F1HZ-6013010-CAJ (replaced E8HZ-6013010-C8A) .. Floor Mat / Obsolete
No Ford dealer or obsolete parts vendor has either part number.
  #158
Old 03-27-2014, 06:56 PM
BADDBOYY21's Avatar
BADDBOYY21
BADDBOYY21 is offline
F600 Vin Decode
Any help decoding would be appreciated. I just purchased this truck today.
VIN 1FDNF60H3GVA21057
Warranty Code 141F60212BK8 SP FPM
  #159
Old 03-27-2014, 09:41 PM
NumberDummy
VIN: 1FDNF60H3GVA21057
Certification Label: W.B. 141 / TYPE/GVW: F602 / 12BK8 SP FPM
Welcome to FTE
1FD = FoMoCo USA - Ford - Incomplete Vehicle.
N = Class 6 (hydraulic brakes), 19,501-26,000 lbs. Gross Vehicle Weight Rating.
F60 = F600 2WD (gas).
H = 6.1L (370 cid) 2V or 4V.
3 = Check digit, FoMoCo use only.
G = 1986.
V = Kentucky Truck Assembly Plant.
A21057 = 1986 Numerical Sequence of Assembly, the trucks specific serial number.
141" Wheelbase.
F602 = F600 (gas), 18,500 GVWR
I was able to break out the WB & Type/GVW codes, but I cannot do anything with the rest of them, as they're lumped together.
So, I cannot tell which is (in order?) BODY code, TRANS code, AXLE code. There's no BODY code that begins with a number for 1986 F600/900's.
  #160
Old 03-27-2014, 10:09 PM
BADDBOYY21's Avatar
BADDBOYY21
Welcome to FTE
G = 1986.
141" Wheelbase.
Would a picture of the door jabm sticker help? I have one if it does.
  #161
Old 03-27-2014, 10:39 PM
NumberDummy
Would a picture of the door jamb sticker help? I have one if it does.
Post the little darlin.'
  #162
Old 03-27-2014, 11:02 PM
BADDBOYY21's Avatar
BADDBOYY21
  #163
Old 03-28-2014, 04:36 AM
NumberDummy
Certification Label should read: WB: 141 / TYPE/GVW: F602 / BODY: KB8 / TRANS: SP / AXLE: FPM
141" Wheelbase.
F602 = F600 2WD (gas), 18,500 lbs. GVWR
KB8: KB = Chestnut all Vinyl / 8 = Conventional Cab.
SP: Spicer model CM4054D 5 Speed Manual Transmission.
FPM: FP = Eaton model 15201 Two Speed Rear Axle / 6.29/8.74 / 15,000 lbs. Rear Axle Capacity // M = Ford 7,000 lbs. Front Axle Capacity with Power Steering.
What the 12 refers to, I don't know...as it's not part of the TYPE/GVW code, nor part of TRANS code. Seems to have been added in error.
EXTERIOR PAINT CODE 2K: Candyapple Red.
DSO 14: Pittsburgh PA Ford District Sales Office, where the selling dealer ordered the truck from.
  #164
Old 03-28-2014, 05:48 AM
BADDBOYY21's Avatar
BADDBOYY21
141" Wheelbase.
Thanks! Could I bother your for part numbers for the front fenders and grill and also a dash pad? I am in Pittsburgh so the closer the better as far as place that may have them.
  #165
Old 03-28-2014, 04:17 PM
NumberDummy
Seems to me you asked for parts for a 1970 F750: Front fenders, inner fenders and a radiator support. You didn't mention your location, but I knew it was PA, cuz I looked at your profile.
Only a few of each of these parts were available, so...I listed what I could find...and where.
Dash pad in any color will be very hard to find, all are obsolete, AFAIK, not reproduced. I'll take a look-see for these other parts later today.
Quick Reply: OLD DECODES
