1997 f150 clip on billit grill
Get a clip on. My 97 had the 1 piece grill and I cut the center out w/ a hacksaw and Dremel. Then I had to fill in the upper corners w/ epoxy and bondo b/c the opening in the 2 pc grills is just a little smaller. Sanded, primered, sanded, painted,sanded, clear coat, and sanded and clear coat and sanded 1 more time! Then I had to make brackets to hold the billet grill in. So I spent almost a full day on this little project, get a clip on and you'll be done in under 30 min.
Check motorhaven.com and ebay
