Help me spend my money
Welcome to FTE!
I'm sure folks get tired of hearing this. Is the drivetrain, brakes, fluids and suspension up to the task? If not or you don't know I would concentrate on that before going forward with power mods. I'm not talking intake and exhaust. If your going to be putting out a significant amount of power you have to be able to get that power to the ground efficiently and safely. Hopefully without breaking anything. My two pennies.
Welcome to FTE and thanks for serving!!!!
How much power are you looking for???? Remember, the stock E4OD transmission cannot handle too terribly much power, so if your looking 400+hp, a transmission build is in order.
We can do a lot with $9k. We can probably get you close to 500hp with that kind of coin, but you won't have much if any leftover if you want that kind of power and to do it for $9k, you will have to do some DIY stuff like the electric fuel system and intercooler. So, let us know exactly what you would like and we can help you put together a list for your needs.
Welcome to FTE!
For 400 reliable horsepower, I think I'd do a full build on the transmission and never have to worry about it again. Look at BTS, John Wood Automotive, and RacerX for that. That will take up around $4k from your budget, but is well worth it.
The stock turbo won't be reliable at 400hp, but can get you close. If you want to step into the aftermarket turbo world, you will be reliable at 400+hp, but you will then have to do headstuds, valve springs, and chromoly pushrods which adds on to your budget. I think You'd probably have a little over $9k tied into it if you do an aftermarket turbo, studs, springs, pushrods, injectors, HPOP, electric fuel system, IC, and built transmission.
So, I would do the transmission first then start doing supporting mods as you get money to do them. Electric fuel, IC, HPOP, headstuds, valve springs, pushrods, then get injectors, turbo, and custom tuned chip to put you over 400hp. 160cc stage 2 injectors are good for around 420hp w/ an aftermarket turbo. Hybrids will get you closer to 500hp w/ the right turbo.
