Rough running engine at idle
Old 06-05-2011, 10:51 AM
wheelspm's Avatar
wheelspm
wheelspm is offline
I have a 88 f250 and i replaced the dist. cap, rotor, spark plugs, spark plug wires, and the throttle position sensor and now when i put it in drive and let it idle while holding the brake it seems the engine has created a miss some how. Any idea?
Old 06-05-2011, 11:04 AM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
What type of throttle position sensor is it- adjustable or non-adjusting? See this page for the difference- Ford Fuel Injection » Throttle Position Sensor (TPS)
If it's adjustable, you may have not installed it correctly. Even if it's non-adjustable, it could be installed wrong. You need to make sure there is spring tension on the sensor when installing.
Old 06-06-2011, 08:29 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,173 Likes on 927 Posts
What engine do you have? Check your spark plug wiring for correct firing order and make sure they are routed correctly. Cross-firing is a very common problem on these vehicles.
Old 06-06-2011, 10:02 AM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
I thought of that too, and I could swear there is a diagram somewhere that shows us how our plug wires are supposed to be routed to avoid cross fire but I couldn't find it.
Old 06-06-2011, 10:57 AM
rla2005's Avatar
rla2005
Steve83 has some pics and info here: 1983 Ford Bronco Diagrams picture | SuperMotors.net for 5.0L plug wiring and firing order
Old 06-06-2011, 12:55 PM
DBGrif91's Avatar
DBGrif91
DBGrif91 is offline
Yep, that's the one I was thinking about. Or at least something similar.
JimiLL
15
12-09-2014 12:02 PM
Rifle
Electrical Systems/Wiring
01-22-2012 07:32 AM
blue max
1997-2006 Expedition & Navigator
11-05-2009 09:20 PM
JTD1972
11-19-2003 04:20 PM
wally2117
08-27-2002 10:20 PM
Quick Reply: Rough running engine at idle
