are 8.8 axles any good
Old 05-29-2011, 12:19 PM
xxshine's Avatar
xxshine
xxshine is offline
A 9" would not shear pins or break carriers. It's used for drag racing. Even people with Chevy's use the Ford 9". I have one, and it's done more than the 8.8 could handle. The 9" pinion grabs more of the ring gear than the 8.8 does.
Old 05-29-2011, 12:20 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by jk89cat
you are correct sir!
Being a Ford partsguy by trade (I was, for 35 years), you are prolly aware of the following:
I was sorta correct, cuz D8BZ-4241-A was replaced by D8BZ-4241-B due to a package quantity change in the late 1980's.
When FoMoCo made those gazillions of package quantity changes, the idiots changed the part numbers suffixes, rendering all the previous numbers obsolete.
Since this occurred after the last printing of the 1973/79 car/truck parts catalogs, none have the new numbers. If the partsguy is aware, the O-S-I catalog is required. If he ain't, the customer is prolly SOL!
The most flagrant example IMO was D0TZ-7B097-A which was replaced by B. When still available, some peeps were being told that the part was obsolete. Today, peeps are still looking for the A suffix.
D0TZ-7B097-B (replaced D0TZ-7B097-A & C5TZ-7B097-A) .. NSS Selector Lever / 1965/77 F100/350. This is one a the most frequent part numbers I've typed on FTE, cuz the part is a POS.
ShannonM2
01-25-2007 04:41 PM
aurgathor
10-13-2004 03:41 PM
rustyolred27
11-13-2003 09:53 PM
sternal2000
10-01-2001 08:24 PM
Quick Reply: are 8.8 axles any good
