Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How to Replace Power Steering Fluid
Step by step instructions for do-it-yourself repairs
How To: Power Steering Pump Replacement
I did away with the power steering on my 89 F-150 6 Cyl. Put a manual steering gear box in the place of. Hydraulic power steering is a thing of the past. It was old when it was new, cause of all the problems that went with hydraulic, and the weight too. Now there's electronic power steering.
2000 Ford Excursion, changed power steering box but still have no power steering unless raving the truck up. Any suggestions. The fluid is filled. I checked the system for flow and that's fine. No restrictions, no clasped hoses. That's where I'm at. What should I try next?
PS: you might try the Ford Excursion forum. The users there would have better ideas for you... My knowledge of Ford Trucks is stuck back in 1991 and earlier.
https://www.ford-trucks.com/forums/forum29/
Is there a bolt on option for our trucks? what is the amp draw from the electric motor? IF you have on your truck LET'S SEE PICS!
I'm all up for give FTE users/readers all the options!
Electric Power Steering
Ahhhh, Now I see.
(from the Wiki)
"An engine or motor is a machine designed to convert energy into useful mechanical motion.
Devices converting heat energy into motion are referred to as engines, which come in many types. A common type is a heat engine such as an internal combustion engine which typically burns a fuel with air and uses the hot gases for generating power.
Another common type of motor is the electric motor. This takes electrical energy and generates mechanical motion via varying electromagnetic fields."
(from the Wiki)
Ahhhh, Now I see.
(from the Wiki)
(from the Wiki)
Don't have electronic power steering. Was just saying that hydraulic power steering was old when it was new. I put a manual steering gear box on. The motor just turns a Taurus alternator and water pump ( minus the clutch fan ). Electric fan replaces that ancient clutch fan.
PS: you could technically get rid of everything except the alternator... If you really wanted to see how much drag the accessories put on the motor you could get a elec fan, elec PSP, elec water pump, and elect AC compressor/motor.
No sarcasm.
When I think of a "motor" I think electric, or something else where power is directly applied to it.
I refer to an (internal combustion) "engine" when speaking of what provides motive force to our trucks.
Fuel is consumed to create heat that provides the mechanical motion.
xxshine stated his "motor" only turns the alternator and water pump.
I can see how that could be misconstrued.
#28
OK - so I have a 1966 F-250 in which the PO installed a nice 1988 block 460. We have the same PS pump and bracket. We need to get the PS pump off the bracket. We now see how to do that - THANKS! So now, how do you get the pulley back on? Somehow reverse the puller? Maybe this is a completely stupid question, but humor me
