Sheila: My 1984 Ford Bronco II
Old 05-25-2011, 03:05 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Does not the "accessory" position on your ign. switch provide the same function?
Just a little hazy on the need.
Old 05-25-2011, 03:14 PM
Spider-Kenneth's Avatar
Spider-Kenneth
Spider-Kenneth is offline
The same function as what?
I have an accessory switch on my ign?
I want the switch to basically be the accessory switch,
Old 05-25-2011, 03:17 PM
Spider-Kenneth
but compliant with the start button i.e can't start the truck without the switch on and the button pressed until started.
Old 05-25-2011, 03:23 PM
Old93junk's Avatar
Old93junk
Turn your ign. switch towards you from the off position with the keys in the ign.......acc position.
Old 05-25-2011, 03:24 PM
Spider-Kenneth
Oh, I get it. You're telling me that this is a waste of time?
Yeah, I know. I just think it would be cool. IIIII liikkee cooollll
Old 05-25-2011, 03:28 PM
Old93junk's Avatar
Old93junk
It could be anti-theft measure.
But not too many people steal B2s!
Old 05-25-2011, 03:34 PM
Spider-Kenneth
I usually lock my door... Plus I thought the hidden switch would eliminate theft, usually...
Old 05-25-2011, 03:39 PM
Old93junk's Avatar
Old93junk
The PO lost the door key for mine.............so, I have to remember NOT to lock it.
(J-yard trip to remedy soon)
Old 05-25-2011, 03:41 PM
Spider-Kenneth
Lol, if mine worked on yours, I would send you a copy.
But I don't think the vehicle is old enough for that to work
Old 05-26-2011, 01:45 AM
Spider-Kenneth
Could you draw up an idiot version of this for me? That would be very helpful.
Maybe only the ignition part? http://www.therangerstation.com/tech...n83to882_9.JPG
Old 05-30-2011, 05:56 PM
Spider-Kenneth
New day, new problem... This time it's a little different....
This time it made me late for work (which it has never had a problem with before, usually she is reliable for me)
I have been using my stepfather's rig.
Anywho.... It doesn't seem that the carb is getting gas. If I do get it started it only goes a little way and then completely dies on me. I replaced the fuel filter (up front on the carb) and when I did a little bit of gas poured out... How could I check if it is the fuel pump? I can get it started once in a while... I donno; I am feeling like giving up on it cuz I have no money and the junkyard wants more for the pump than Baxter's for a brand new one... Really I am not feeling like I want to deal with it, but I know I do; I will press on with the repairs it just feels like one thing after the other.
Old 05-30-2011, 06:12 PM
Old93junk's Avatar
Old93junk
Fuel pump is front of motor on drivers side, access is best made by moving the power steering pump. If pump is leaking motor oil from a small hole in housing, pump is bad.
  #28
Old 05-31-2011, 02:45 AM
Spider-Kenneth
K, I will give it a look at, could you believe that the junkyard up here wanted $10 more for a fuel pump than Baxter's brand new one? Nuts, huh?
  #29
Old 05-31-2011, 06:20 PM
Spider-Kenneth
I just removed the dash (to replace the fuel gauge) I broke that white clip connecting the cable to the speedometer... Am I in trouble or can I get a new plastic thing, maybe tape will work? I didn't know how to take it off.
  #30
Old 05-31-2011, 06:24 PM
Old93junk's Avatar
Old93junk
You just squeeze it together with your thumb and forefinger.......it pops off.
You can try jamming it in till it stops and duct taping.........If not, your on your way to the junk yard.
Quick Reply: Sheila: My 1984 Ford Bronco II
