1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2000 F350 Powerstroke Charging Problem
Old 05-05-2011, 09:41 AM
sareed's Avatar
sareed
sareed is offline
Alright, I have had enough. I have a 2000 Ford F-350 Powerstroke Diesel. About a month ago I noticed my batteries were dead after a few days. I removed battery terminals and cleaned them, as well as the power cables to and from the starter solenoid. Same thing again. I also started noticing that my voltmeter on the dash was very low in the normal range. So I removed both batteries and had them checked at my local O'Reilly store. Both batteries are three years old and both checked fine. I then removed my alternator and had it tested. It tested good in two tests. Since I was bored, I also removed my starter and had it tested. It also was good. Replaced them all, same thing. Since my alternator had a lifetime waranty, I replaced it. No change. I got my book out and found out I had no voltage coming to the alternator at the trigger wire. (light green with red stripe). I then traced the wire through the truck and found a broken wire at a connector behind the right side battery. It was some sort of plug that just had one wire loop. So, fixed that, had voltage to the trigger wire. Thought things were good. But now, I have a battery light coming on in the instrument panel. It slowly flashes at idle, and is on steady at higher rpm's. I checked the alternator with a voltmeter and found 14 volt output at all rpm's, but light is still on. Any suggestions? This is driving me crazy.
Old 05-18-2011, 08:32 AM
sareed's Avatar
sareed
sareed is offline
Yep, I am stumped also. Took my truck to a mechanic and he tested the truck for a battery draw. He told me that my GEM module did not appear to go to sleep like it should because it was pulling more amps than it should when it was not running. Hmmmm, so why when I drive it for 20-30 minutes and shut it off will it not restart? I might buy that more if it happened when the truck had been setting for a while. And of course the GEM module it a little expensive considering there is the part cost, the installation cost, and a programming cost. They get you coming and going.
kr98664
'80-'86 HOWTO's
22
02-17-2024 10:15 AM
gearloose1
01-01-2020 05:03 PM
ctubutis
Testing.....
08-15-2017 11:03 PM
gardeman
29
05-02-2017 07:45 AM
ryank59701
10-19-2015 02:04 PM
Quick Reply: 2000 F350 Powerstroke Charging Problem
