1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 f350 7.3l 4x4 rearend diff fluid
Old 05-16-2011, 08:54 PM
bubba_v2008's Avatar
bubba_v2008
bubba_v2008 is offline
i have a 99 ford f350 lariat 4x4 i have to change the front seal on my rear diff. i know what kind of gear oil to use the 75w140 synth i plan on using the royal purple my question is how much do i need i want to completly change the fluid. my other question is what rearend do i have there is a tag on the rearend that reads 3 S 409 E
L73 10 5 9F24
any help will be greatly appriated thanks.
Old 05-17-2011, 05:31 AM
brian42's Avatar
brian42
brian42 is offline
The "L73" would indicate that you have a 3.73 Limited Slip differential in the rear.
IIRC my rear took just under 2 gallons (8 quarts) to fill from empty.
Old 05-17-2011, 01:00 PM
bpounds's Avatar
bpounds
bpounds is online now
It is not nearly that much.
Assuming this F350 is a SRW model, you have a Ford Sterling 10.5" rear diff. Fluid capacity is 3.3L. You will need to buy 4 quarts and will have a bit left over.
As Brian said, it is limited slip. So make sure the oil has friction modifier built in. I'm pretty sure RP does, but check the bottle. Mobil 1 is also a good choice. Synthetic is required.
Old 05-17-2011, 03:22 PM
Kajtek1's Avatar
Kajtek1
Kajtek1 is offline
The best is to find a manual. I do have Dana80 what is the biggest (?) differential installed on those trucks and 2 gallon bottles had lot left in the second.
Always good idea is to measure drain oil for starting point.
Bennie Morton
04-06-2017 09:47 PM
dyoungen
02-21-2012 02:58 PM
bubba_v2008
05-16-2011 11:32 PM
3wheeler
01-13-2008 12:26 AM
jimbo beam
109
07-01-2007 05:21 PM
Quick Reply: 99 f350 7.3l 4x4 rearend diff fluid
