M5OD 2wd to 4wd??
Pretty sure the 4x4 trans is going to have a different tailshaft housing. Converting may require complete disassembly.
M5OD behind a 351w? Take it easy.
Have you considered the ZF?
HOWEVER, what pattern is your TC to trans pattern? You need to confirm these will bolt to that TC. What model TC is it?
Don't have the transfer case yet. The 351W I'm building is not going to be a monster, so I thought I'd go with the M5. May just wait until I can find the tranny/ tc all together. Unless I run across a ZF that someone doesn't want a ton for, and one that will fit a 351. Most I've seen fit the 460
Eli1644
09-24-2015 12:36 AM
fudimanuchi
04-01-2012 07:06 PM
1badshovel
05-16-2011 11:19 AM
