Stock Cluster question
Ok i have a 74 f150 and i am trying to get a new cluster or one that works. Well mine has the green printed circuit board. I bought one off ebay and it is i believe from a full body bronco. It has the red circuit board. Well for one the connector that plugs into the instrument cluster the connector for the green is smaller than the one that connects to the red circuit board.
Well is there a pig tail i can get and cut the old one and splice in the proper one?
Trying to use the new circuit board. my green board has some copper strands broken. Thanks
I have the plastic pigtail housing and the red lock that hold the wires in if you are interested. I disasassembled mine, rather than cut it, so I could run the wires I need for my new dash.
You can simply pull the red lock out of yours and slide the wires out and put them back into the piece I have. Better than cutting.
Let me know and I can send it to you.
Mark
Mark
Black Jack G
12-10-2011 12:30 PM
77429highboy
07-13-2011 05:13 AM
