Wish I could lend a hand fellas, but I already know I have to work this Sat and will be out of town the next, so..... don't work too hard. And Joe, I hope you get your truck back on the road.
No worries Jeff, we all know how you feel about working on powerstrokes anyway...
Originally Posted by zhilton
I've got four 3-ton jack stands and a 3 ton floorjack....the sad part is I'm working Saturday as well. After last week's firestorm (management playing dirty) and a 12 day paid vacation coming up...I need to work as much as I can right now and get my name back below the radar. One of these days I'm going to make it to a wrench party.
PS: If someone is willing to come to FSM, I can have the boy help you load the stands & jack. I'd have him run 'em down...but at 10, he's not covered by our insurance policy
Hey he's only 4 years away from learner's permit time, you gonna let him drive the princess?
Originally Posted by cookie88
I've got a pair of 6 ton stands and a 3 ton jack. I'll bring them.
Awesome, thanks
It has turned into quite the little pile of goodies. Of course if I can't get it running before then we might spend our time hunting down ghosts.
<iframe title ="Preview" scrolling="no" marginheight="0" marginwidth="0" frameborder="0" style="width:320px;height:239px;padding:0;backgrou nd-color:#fcfcfc;" src="https://skydrive.live.com/embedphoto.aspx/.Public/d8.jpg?cid=252b282fb69007b3&sc=documents"></iframe>
Anything there that I'm missing? besides some anti-seize and some pb blaster to soak down the exhaust?
Are you noticing the tach moving while cranking? Do you have AE or a scanner to monitor RPMs while cranking? I hope it is the CPS, but just trying to help diagnose.
It bounces a little, I'd say one bounce per 5 secs. of cranking
I've got a superchips that I use to pull the codes, but it doesn't have any way to monitor RPMs.
It was idling in park, and it just died as though you shut off the key..no stuttering or stumbling
One of these days we're going to have to have an intervention with Jeff and convert him over to the dark side
Eh, we'll see...that allot of power under the hood for a teenager to handle. Right now the plan is to "loan" the Explorer to him. I figure the 4.0L is underpowered enough to keep him out of trouble...but will run fast enough to get him a speeding ticket; that will cost him driving privileges. He doesn't bother me as much as his sister...I think I'm going to take up drinking when she turns 16. By the way, thanks for reminding me that I'm getting older.
Originally Posted by Will P.
I'd like to help out but I'll be working also. I don't know much about diesels anyway.
Once you learn to speak Powerstroke...you can fix any Ford from that point on. The PSD are the cream of the Ford crop...nothing higher on the food chain.
I've got a superchips that I use to pull the codes, but it doesn't have any way to monitor RPMs. It was idling in park, and it just died as though you shut off the key..no stuttering or stumbling
Since I drive the black sheep of the chapter () I can only throw a couple of ideas out there. When you said it died like you shut the key off...I thought ICP. But if it was that, you should be able to get it to restart...especially if you unplugged it. It would restart with the ICP unplugged which would confirms it's the ICP; your mileage & performance would suffer...but I don't think that's an issue right now. Still sounds like the CPS or part of the harness leading to it.
I have to work tonite we had equipment breakdowns on the well and put us behind, hoping to finish it up by Sat am . I will be over just a matter of when.
What time are you looking to kick this off Joe? I will try to head up that way for a bit, just need a chair for my dad to sit in cause he can't stand very long.
Alright, I replaced the CPS and no joy... so I moved on the fuel system..
I put a hose on the fuel bowl drain and opened the valve, turned the key on and I just had a trickle out of the drain. Pulled the filter and my god what a mess in there.
I spent the next 2 hours getting all the mess out of the bottom of the bowl, and the drain was plugged at the top.. got a new filter in it and I had a good stream the size of the pencil out of the drain.. still no joy
Right before I called it an evening I pulled the plug on the ICP and it's full of oil.. might this be the culprit?
