2011 Shudder at 5 kph
#166
#168
#169
Finally got the Roadmaster Active Suspension installed on my F150 Screw. I let the garage install them as they have the lift etc. making it easier. I am carrying about 600lbs between the 6.5' bed and rear seat. The shudder is not totally gone but barely noticeable now, the mechanic advised me to drive around with it for a week or so to give the roadmaster setup a chance to work itself in, he then wants me to come back to adjust the pre-tension (a part of the setup procedure) to see if we can totally eliminate the shudder.
The overall feel of this setup is fantastic when driving and cornering etc. It gave about 1.5" of lift over stock.
The cost was about $470. cdn. installed
#171
Acceleration shudder diagnosed by Ford! - Ford F150 Forum - Community of Ford Truck Fans
Maybe it's a Ford recognized fix?
#172
New Springs
I just had my rear leaf springs replaced under warranty to address the shudder.
Driving the truck unloaded felt much better. I couldn't even detect any shudder when accelerating from a stop. Next week I will haul my boat and load down the bed to see if the shudder comes back.
Ford seems to have a fix. Hopefully the truck won't shudder under load.
There is a new TSB on the shudder. Ford has recognized the axle wrap issue...
Here is the part number of the new leaf springs if anyone is interested:
AL3Z-5560-C (Springs look much more robust than the older ones)
My truck is a 2011 XLT Screw with 6.5 foot bed. Mfg. on November 2010.
#173
You mentioned in an earlier post that they were going to shim as well, did they do that also?
#174
Based on Rancheroracer's comments, I may not be out of the woods yet. He loaded his truck down and the shudder returned, but not as bad as before.
Rancheroracer - Have you been in contact with Ford lately?
#175
#176
Do you have the new TSB number and details that you could share as you mentioned above?
Thanks
#178
I just found this online concerning TSB 11-9-17. Interesting that it specifies CREW cab and not SCREW.
TSB
11-9-17
Released Oct 3, 2011
ISSUE:
Some 2010-2011 F-150 CrewCab 4X4 with 3.988 m (157") wheelbase built on or before 6/21/2011 may exhibit a shudder/vibration on moderate to hard acceleration.
SERVICE PROCEDURE
It is important to confirm how the vehicle is driven the majority of the time (loaded or unloaded) as adjusting the driveline angle may result in a shudder or vibration if vehicle payload changes frequently.
This procedure should only be used to correct or improve a shudder or vibration in described condition as per vehicle build configuration.
Some shudder/vibration on take-off may be normal under heavyload or trailer tow conditions. Refer to the Owners Guide and Towing Guide for additional information/specifications regarding towing and vehicle loading. With spring configuration on 3.988 m (157") wheelbase, the shudder/vibration concern may occur when loaded or unloaded.
This procedure will improve the severity of takeoff shudder/vibration based on vehicle load conditions.
The procedure Has you change pinion angle with spacers and/or replace rear springs to the latest revision level to Help IMPROVE the shudder.
TSB
11-9-17
ISSUE:
SERVICE PROCEDURE
#179
I just found this online concerning TSB 11-9-17. Interesting that it specifies CREW cab] and not SCREW.
TSB
11-9-17
ISSUE:
SERVICE PROCEDURE
TSB
11-9-17
ISSUE:
SERVICE PROCEDURE
J/C man! I've been complaining about this since February, 2011 and I have a Super Cab! I have the same wheelbase but experience the same thing. I have 2WD and was built on 12/22/2010.
Why isn't my type truck included in this TSB?
Come on FORD!
AHHHHHHHHHHH!! **** me off!
#180
Any updates you guys can share on the spring changes? Have they helped on loaded and unloaded conditions? Towing?
I am going in this morning to get the spline yoke problem solved, but this will not address the shudder I have, only the bump feel when I accelerate from a complete stop. I am going to mention the spring replacement and spacers.
Thanks
Thanks
