2011 Shudder at 5 kph
Shudder or vibration at initial acceleration
I have a 2009 F150 Super cab with 6.5’ bed with the two part drive shaft.
I have the same problem as is described in these threads. Here is what I have learned so far:
Dealer replaced the boot and silicon grease on the slip joint of the split drive shaft.
Dealer found a Technical Service Bulleting describing the realignment of the drive shaft support bearing.
After doing both of these procedures, the shudder is greatly reduced but it is still noticeable and I suspect that when I tow our ski boat, will notice it more than driving without this load.
I am interested in learning what else may be causing this problem.
Wandering Elk
Wandering Elk
Shudder
Hi - I have a 2011 F150 Supercrew with the 6.5 foot bed. At low speeds 0-30 mph, I experience vibrations through the gas pedal and steering wheel. The vibrations only happen when the truck is accelerating and when it is under load. The truck was road tested by a Ford tech and he also noticed the vibrations. I'll let you guys know when the truck is repaired next Tuesday. I seem to think it is drive shaft related...
Shudder @ low speed acceleration
Thanks for this reply. I am very interested to see what they may find. Ask if they can do a dynamic test I'm the whole drive shaft. Another option is to mount a wireless camera with a strong magnet focused on the bearing and then do a road test to see if the shudder source can be identified. We will all keep shooting in the dark until someone can identify the root cause. Since your dealership tech has felt it, please ask him if he can search the Oasis data base to see what might be listed there. My last recommendation is to find a contact in Dearborn for Ford Parts & Service in Dearborn to see if there is any engineering investigation going on about this issue.
For people that feel the shudder comes from the torque converter or tranny, somebody from another thread suggested using.....
LUBEGARD Automatic Transmission Fluid Protectant
However if you read this carefully it says "EXCEPT FORD"
Well, truck's in the shop today - going to change the Valve Body. Supposed to be ready tonight. I've mentioned that I could feel the shudder when accelerating quickly so I'll see if it makes a difference when I pick 'er up tonight. I'll be towing my 8K load this coming weekend where the "real test" will be.
I'll post what I discover tonight and then again next week after I come back from camping.
Wish me luck!
Wish me luck!
I DID discover a NEW issue though... when I drive slowly, shifting from 1 - 2- 3 at low RPM (1000 to 1500) it "slams" into 4th gear - HARD. Didn't do THAT before.
I drove it straight home from the dealer and will try again tomorrow to see if the 4th gear slam still happens.
Grrrrr
Took the truck at lunch and the 4th gear hard shift seems to be gone however; I am getting the subtle feel of the tranny shudder again at the end of 1st and 2nd gears.
I'm going to get my camper in the morning and will hopefully post my results after I get it home and before I leave for the weekend. If not, I'll post again on Sunday night.
Update:
Real simple - it didn't work. Rumbles just as it did before - as a matter of fact, I think it's worse.
Let me explain... the service they did certainly didn't help and when I say " I think it's worse" I mean it was getting worse every time I towed - even before the service. I don't think they made it worse, I think their service wasn't focused on the right issue.
I hope this makes sense.
I'll be taking it in again soon - possibly next week.
#28
on
i went through this shudder problem and endless diagnoses on a 2003 Lariat.
Flashed the computer several times, changed the driveshaft and a whole bunch of other stuff and they never did find it after dozens of service visits and loaner trucks...finally settled on a free extended warranty. Then lost the truck in a write-off accident (best thing that ever happened to it!) and they wouldn't move the free warranty on my new truck. All this to say "got screwed".
Good luck.
Good luck.
#29
Good luck.
Good luck.
