Push button start?
Old 05-09-2011, 09:20 AM
vinny80's Avatar
vinny80
vinny80 is offline
Push button start?
well, my ignition has gone bye bye lol, and i wanna hook up a push button to start the truck when the key is in the on position, where would i hook the wires for the button up too?
Old 05-09-2011, 11:12 AM
f100jim's Avatar
f100jim
f100jim is offline
A new ignition switch is $9.99. Why not just replace it?
Old 05-09-2011, 12:23 PM
kevin206's Avatar
kevin206
kevin206 is offline
Do you still have power in the ON position? I bought an 89 recently that had a bad switch. I think that the rod actuator was broken. I have a push button on the dash to activate the starter. I just has wires that run from a HOT back to the S on the starter relay. I also have a toggle switch that splices into the underdash wiring that turns everything on and off. With this particular setup I have no ACC position. Doesn't really bother me, but it could be an issue for some.
Old 05-10-2011, 12:38 PM
vinny80's Avatar
vinny80
vinny80 is offline
i have the same thing kevin206..i have a switch to turn the power on, but the key wont start the truck, it has power but when i turn it to turn over the truck, nothing happens, and the rod is still good..
Old 05-10-2011, 02:10 PM
ctubutis's Avatar
ctubutis
ctubutis is online now
Use a small jumper wire to jump #3 and #5 (with tranny in Park or Neutral).
If the start starts turning, the problem exists from that point back to the steering wheel.
If the starter doesn't turn, the solenoid is shot (bewrare of Chinese-made solenoids, they have a bad reputation here).
cbrd1999
1983 - 2012 Ranger & B-Series
05-30-2017 04:50 AM
duramaxthis
1999 to 2016 Super Duty
20
05-25-2017 07:15 AM
Dhudec
2017+ Super Duty
03-23-2017 08:16 PM
OneTon4Fun
02-14-2016 04:36 PM
79CAMOFORD
63
12-24-2015 10:36 AM
Quick Reply: Push button start?
