Onboard air, airbags, horns - complete
#46
tons of these compressors have been out in the elements for a long time.
#47
I have been mounting my viair compressors under the cab since 2008. Never once had any problems but I only drive in the salt belt a half dozen times/year.
My current set up is the same shocker horns you have and the viair 10009 kit (2 compressors). This truck is my first long bed and I was able to mount both compressors directly above the drive shaft just aft of the carrier bearing, perfect spot and it appears that it stays dry up there. Still looks brand new.
My four shocker horns are mounted to the under side of the bed floor just in front of the right rear wheel well. They appear to be dry as well.
Have fun!
Have fun!
#48
Have fun!
Have fun!
#49
#50
Depends on the water source? Any chance that water is entering the horn from the front as you drive?
I'm sure the dryer will help and I always feel like I've done a half azzed job on my system since I don't have one but I've never had lines split either. On my 2008 truck I couldn't use the compressor because the air lines would freeze, but they never split.
#51
#52
#53
The air lines pass thru there and lay flat under the carpet, go up the firewall behind the brake/throttle pedals and across into the storage pocket by your right knee.
In the past I have run the air lines thru the rubber seal that surrounds the steering shaft also.
I've never gone high enough with them to reach that pass thru wire bundle.
#54
I bring them up through a rubber grommet that is under the carpet and it's kind of in front of where your heel sits if you were to use your left foot for braking.
#55
There is a 1/2" air line run from my tank to the manifold/electric switch. From the switch manifold there are 5/16" lines going to the four horns.
I will need to confirm the 5/16", it's the size that hornblasters used.
I tried to change the size and fittings but I couldn't find any parts that would match properly. The solution was actually simple, my local fastenal store just happened to have the 5/16" tubing. Only place I've been able to source the stuff.
#56
All kinds of oddball air PTC fittings.
What I can't find there I have been able to get either on Amazon or ebay.
Suspension Parts - TruckSpring.com
#57
I got my viair kit yesterday and looking it over it seems that the designers had the Ford super duty in mind when they made this kit. I am not a fan of drilling holes in frames or using the "pinch" method of mounting so if I "frame mount" this kit I either need to build my own brackets to use pre-existing holes or abandon the frame idea and use the body. I done some looking underneath and got an idea but want to get some input before I proceed .....
I got the compressor bracket as well as the complete kit and the pre-drilled holes (bracket and tank) are a damn near perfect match to the pre-existing holes in the body where the side steps would mount. Seeing that I have no side steps (nor will I ever) I think this would be the perfect location for an onboard air system? Granted if I get t-boned it'll destroy it, but if that happens I think a $350 air system is the least of my worries.
Is there any reason not to body mount this kit?
#58
A LOT more noise in the cab. I had mine mounted to the body for a short time.. couldn't take it..
#59
#60
https://www.ford-trucks.com/forums/1...l#post15154636
