Project Sandy - Jaime's Project thread
Old 04-13-2015, 08:31 PM
Jaime74656's Avatar
Jaime74656
Jaime74656 is offline
true, i understand, just need to get welding equipment....uuug...
  #242
Old 04-13-2015, 10:26 PM
Jaime74656's Avatar
Jaime74656
Well I touched up the clear coat on the truck early today before the rain so I hope that helps protect the paint some
Granted the touch up pen, is not the same colour of the truck but the clear coat part is still usable, I got the G2 colour which is for the stang so I been touching it up through out the day trying to make the stang look a bit better then how I bought it!!
  #243
Old 04-18-2015, 11:29 PM
Jaime74656's Avatar
Jaime74656
Well spent Friday fixing the truck, got new ball joints, and replaced the tie rods and fixed the exhaust leak, so all that is left is to get an alignment for it.
  #244
Old 04-26-2015, 07:39 PM
Jaime74656's Avatar
Jaime74656
went to the parts house (where I now have a job at...YAY) and purchased the thermostat and the housing, had to order the gasket off the website so im waiting for delivery of it...
excited to get that all fixed up though, figured even if the housing and gasket are still good might as well replace them while its all coming off, so at least I know it will last a good while longer!!!
  #245
Old 04-27-2015, 05:56 AM
Bob Gervais's Avatar
Bob Gervais
Bob Gervais is offline
Congrats on the job! Good to hear you're still fixing the truck up too.
  #246
Old 04-27-2015, 09:17 AM
Jaime74656's Avatar
Jaime74656
Yup im excited about it, and jst because I got a Mustang doesn't mean the truck isn't going to get any less love It just means it has a brother!
  #247
Old 05-04-2015, 07:56 PM
Jaime74656's Avatar
Jaime74656
Well got the thermostat changed and the gasket changed but issue still persists I think, also noticed a leak
  #248
Old 05-05-2015, 04:11 AM
Bob Gervais
What was the issue that caused you to change the thermostat?
  #249
Old 05-05-2015, 07:37 AM
Jaime74656's Avatar
Jaime74656
The engine wasn't getting up to proper temperature plus minor leaking of coolant
  #250
Old 05-05-2015, 12:04 PM
Bob Gervais
Gotcha. You installed a 195 degree thermostat, right?
Mine leaked a little, turns out the thermostat outlet had a hairline crack in it that I missed. But you replaced your outlet right?
  #251
Old 05-11-2015, 11:08 PM
Jaime74656's Avatar
Jaime74656
no I haven't replaced the outlet (yet) I did make sure to scrape all the old gasket out/off and replaced the one gasket, but im starting to wonder if theres really a second one also for the tstat its self...
  #252
Old 05-12-2015, 05:51 PM
Bob Gervais
Nope, just the one gasket! I've found that lightly brushing on some RTV works pretty well on most gaskets. Helps hold them in place, and seal up any minor imperfections.
  #253
Old 05-15-2015, 11:52 AM
Jaime74656's Avatar
Jaime74656
Well got the truck in the shop today, and got the work sorted out and done!!! Runs much smoother now!
  #254
Old 05-15-2015, 05:48 PM
Jaime74656's Avatar
Jaime74656
next will be a $190 purchase for a new alternator and serp belt!! (fun) I know its just three bolts to pull the old and then disconnect the connector(s) and then put the new on, but I suspect I will have to go through 50 other things, but as long as its just remove the tentioner pully and belt then the alt and reverse the steps I suppose all is god right?
  #255
Old 05-15-2015, 05:51 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Make sure you are pulling the paper off the thermostat gasket. I was a dummy and left mine on and it leaked. Pulled it off and dad showed me my problem. Pulled the paper off the new gasket and no leaks.
Trav
Quick Reply: Project Sandy - Jaime's Project thread
